12 members (John V6, IcePack, JohnHarris, Chris Cosher, GrumpyPa, +8Rich, Graham, G4FUJ, MartinB60, RichardV6, High Hamster, Morganmike, TalkMorgan),
299
35
Topics49,904
Posts838,092
Posts: 898 |
Just had a look at this site. I could not believe the range of older cars they have towbars for. Worth a read. http://www.watling-towbars.co.uk/docs/pricelist.pdf
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
is there any rear end construction difference between the plus 4 and the plus 8? wouldnt the plus 9 bar fit a plus 4?
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
The chassis would have been wider on the plus 8 in those days, having said that its only the length of the horizontal angle iron that varies as far as I can recollect. I have a towbar on my ‘69 4/4, Factory supplied.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 9,554 Likes: 134
Posts: 9,554 Likes: 134 |
Ray....where are you? Your towbar looks quite solid!
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Ray....where are you? Your towbar looks quite solid! no problem with the tow bar, even used to tow microlight caravan. As said if chassis rails are the same width they should fit any model. Mine bolt directly to the chassis rails.
