6 members (+8Rich, sprinty, JohnHarris, IcePack, RichardV6, Morganmike), 270 guests, and 41 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,090
#509972 23/04/18 05:46 PM
E
E
Just had a look at this site. I could not believe the range of older cars they have towbars for. Worth a read.
http://www.watling-towbars.co.uk/docs/pricelist.pdf
is there any rear end construction difference between the plus 4 and the plus 8? wouldnt the plus 9 bar fit a plus 4?
The chassis would have been wider on the plus 8 in those days, having said that its only the length of the horizontal angle iron that varies as far as I can recollect.
I have a towbar on my ‘69 4/4, Factory supplied.
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Ray....where are you?
Your towbar looks quite solid!
sospan #510066 24/04/18 09:16 AM
Ray Offline
no problem with the tow bar, even used to tow microlight caravan. As said if chassis rails are the same width they should fit any model. Mine bolt directly to the chassis rails.
