3 members (Jensen1960, Alistair, Image), 352 guests, and 58 robots.
+8Rich 81
Topics49,859
Posts837,501
Jonny72
Page 3 of 4 1 2 3 4
Glad to hear that.
Here in the UK it is fantastic weather, the side screens are off & if really warms up the aero screens may come out to play.
Enjoy your car.
My 4 4 sport suffered the crack 2 months after delivery. one straight broken line on the drivers side. the factory acknowledged there was an issue and via my dealer replaced it under warranty.
greetings
Hello Juergen,
well, seems like Morgan really had an issue with a batch of 4/4 Sports windscreens. frown
You are now the 6th, or 7th person I know who has run into the same problem. Was it a dented frame as well?
When was your car manufactured?
4/4 Sport 'Sports Red' (12/2009)
Greetings from Switzerland
Wilhelm
hi, the car was manufactured May 2010.
regards
juergen
i hope the replacement is of better quality.
Hello Juergen,
the replacement windscreen is just doing fine.
The crack in the glass of the original windscreen was due to a manufacturing error: the frame had been pressed too much on the top left corner. When a ruler was put across the corner of the old frame I could clearly see the gap between frame and ruler exactly where the crack in the glass started!
Whereabouts are you located?
regards
Wilhelm
Wilhelm
Hi,
I am located in northern germany, my dealer is morganpark in hamburg. they do an excellent job all over.
regards
juergen
Hello,
sad news. I got a warranty windscreesn and after 5 weeks the new windscreen again cracked the same way. I do not know what they do with the screens at MMC.. So ,after 7 months a brand new 4 4 sports gets the 3d windscreen. any coments?
best
Juergen
Have you had the hood up Juergen?
If so, there may be some excess tension causing this?
Do you use siwel pivots for an easier closing ?
It makes less tension on the wondscreen when you put the hood up ...
Maybe it's the reason why ?!?!
Hello Jürgen,
sad to hear that you had such bad luck with the replacement windscreen. frown2
What did MorganPark say as to the crack of the original windscreen? Was this due to a dented frame (as was mine)?
Earlier this month I came across another 4/4 Sport (grey) at the British Car Meeting in Mollis (CH). This one had the same type of crack in the windscreen. ... Unfortunately the owner left with his car before I could leave a note. All I know is that the car has Zürich numberplate.
I talked to my local dealer (Abt Automobile) recently. So far this kind of crack has only been seen on 4/4 Sport cars. mad2 Looks like the manufacturing and fixing of the 4/4S windscreen is different from the other models.
Wilhelm
Page 3 of 4 1 2 3 4
