7 members (Burgundymog, James B W, TBM, Clipper, noddy, RedThree, DCH),
155
199
Goodwood
Topics49,931
Posts838,503
Posts: 338 Likes: 7
Posts: 338 Likes: 7 |
The sump is a good mod. The first Mog +4 I had with the TR engine had a low sump pan. I holed it on the front gate stop and dumped all the oil on the driveway. I also scratched up our motorhome last week, backing into the driveway. I hit the mailbox for the third time............
'34 Family 4 '70 +8 '03 Hummer H2
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Repair is slow I’ve realised my method of building up the paint wasn’t the best so I’ve sanded back and I’m preparing for some high build primer
Posts: 22,385 Likes: 358
Posts: 22,385 Likes: 358 |
Why dont you get chips away to look at it Stewart?
Its very difficult to get a good diy finish.
Its very difficult to get a good diy finish. You know me I’m detirmined to have a go at it myself - it’s all a learning curve I took a ‘brass rubbing’ of the area and masked the area and have got several layers of high build primer on it
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Stuart, you have my sympathy.. I backed the red 4/4 into the garage late one evening & scraped the rear wing on the brickwork.
Have to say I admire the way you're having a bash at some repair work yourself, after all if you have to pay someone to fix it professionally, you may as well have a play first.
I'm probably wrong, but shouldn't you feather the edges of the paint before you apply the primer..? It just appears that you'll be hard pushed to get that ridge edge down.
I did with some sandpaper and then made my mask about 1mm larger than the area all around
Pleased with the high build primer Now to sand down and smooth out
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
You’re a braver man than me Stuart attempting that repair. Hugely impressed that even the tape you’re using matches the car. Looking forward to seeing the end result.
Bud 4/4 "Stanley"
Posts: 6,538 |
Well done Stewart.
Keep at it! And hope it continues to go well for you.
Neil
Yahoo Chuffed to bits Got the modellers airbrush out and have just given it its first coat I’ve got the tiniest of runs but I’m confident with a bit of polishing - my garage wall scrape never happened
