7 members (Biggle, Lordofthewings, Paulxj, DJC, JMD, TBM, MartinB60),
303
45
New
Topics48,365
Posts813,361
Members9,215
Posts: 1,944 |
I removed the front baffle from the standard silencers & now the pipes do not glow red quite as much.
Posts: 3,660 Likes: 48
Posts: 3,660 Likes: 48 |
Quick question on how hot the exhaust pipes get. When you guys are driving down the road at night slow speed (ie 35mph) if you look at where the pipes exit the cylinder do they give off an orange/red glow.
I have never really looked at mine until after I installed new cams and ECU from garage 56 and noticed the glow. I need to get a full dyno tune but wanted to check if this is normal Absolutely. Absolutely not! With MMC Stage 1 (or G56/removed baffles) the gas flow is improved and you shouldn't get the red hot headers any more.
Red Leader
Posts: 103 |
Have you removed the cats?
Posts: 365 |
The cats I believe are there as it is factory stage 1. My concern is I might be running too lean. I am waiting for the roller rockers and once they are on I will go for a dyno tune to check it all out. Just want to make sure it is safe to drive it there. If an orange glow is not abnormal I suspect in general it is safe to drive it there.
2017 M3W Sport Green
Posts: 2,539 |
I punched holes in my front baffles and my black header wrap stopped turning white!
Posts: 99 |
Like I said from the top...Magnaflow the name says it all! They are totally straight through and the sound can’t be beat, all for around $300 for you “do it you-selfers” . Now over a year driving with them and I’m still very pleased. And the originals are stored on the shelf if I or someone down the road wants to put it back to factory spec. (Listen to my Blog below) High Noon My Blog: https://ontheroadtonowhereville.wordpress.com/
Posts: 189 Likes: 1
Posts: 189 Likes: 1 |
Did you happen to take any photos of the brackets themselves? I really like MFs as I have them on my supercharged truck for extra throughput. Thank you.
2018 S&S 110th Beetleback 1934 MX4 Beetleback 1965 Corvette Coupe 327/350
Posts: 488 |
Just done a “High Noon” First impressions it’s LOUD!! Tick over is is a nice deep sound, louder than standard pipes with number 1 baffle removed, cruising around with a gentle throttle sounds great . I used an extra flexi rather than having the pipe bent and it’s a tight fit under the guard but like High Noons the standard pipes can go straight back on if needed. Giving it the beans sounds nothing like High Noons video, it’s got a real bark to it and is v loud, Extinction Rebellion are not going to be amused! Thank you High Noon for the idea, I’m happy, not sure if the neighbors are. ![[Linked Image]](https://www.tm-img.com/images/2019/10/19/5378181B-0F84-43EB-A690-41DD2F6B47EC.jpg) ![[Linked Image]](https://www.tm-img.com/images/2019/10/19/250F7148-ADDF-4AC9-AA79-A01B7647B2E1.jpg) ![[Linked Image]](https://www.tm-img.com/images/2019/10/19/80A5CCDC-614D-42DE-8046-EF6283278379.jpg) ![[Linked Image]](https://www.tm-img.com/images/2019/10/19/577D1B0C-1304-4ABF-896D-CFDBBC415E28.jpg)
Posts: 3,854 Likes: 2
Posts: 3,854 Likes: 2 |
Nice, I see you made the stinger about the same length as the one on the AR Stage 1 kit that I have. And the AR kit is indeed loud when you step on it.
Posts: 1,670 |
It looks great and I bet the engine breathes easier now
