Think I might have to do the same for the airbrush kit.
Another scratch at bottom of n/s/r wing from neighbour's driveway when I returned home from the factory this afternoon
If interested, my airbrush is the Aztec A320 (bought as a set A3205) made by Testors. It’s quite a cheap one but a good alrounder. I think from memory it was around £30 10 years ago.
The important thing is getting the right colour paint and thinning it down to the consistency of milk so it flows through the nozzle
And when you first get it try it with water first on some paper to get used to it and the adjustments in the cone of spray
Also recommend getting the airbrush cleaner station which is a large cyclindrical tin with a nozzle to insert the brush to fire thinners into to clean up after use
And also a couple of spare paint reservoir bottles with screw cap lids so you can keep the paint that you mix up for a few weeks
The high build primer I used was the Simonez aerosol - you must mask the area well when using this but it superb and can be layered up in only 15 minutes
