10 members (TalkMorgan, hugo, RichB, Rex_tulips, Zach, RichardV6, RedThree, DaveK, howard, lez),
303
41
Topics48,362
Posts813,332
Members9,215
Posts: 759 Likes: 23
Posts: 759 Likes: 23 |
I've been bothered since I got my 3W by the unnatural angle of the fuel hose where it connects to the injector block on the top of the motor. While replacing the rocker box bolts with non rusting stainless items, I noticed some small cracks beginning on the near side hose at the point of maximum stress, so time to do something. I decided on removing the injector block and tapping it for a -6 AN adaptor which I then connected to 45 degree -6 AN to -5 hose barbs. Shortened the hoses just a bit (which removed the cracks) and now I'm much happier with the stress free hose connections.   And while I was in the mood... I decided to replace the brake fluid reservoir which has also seemed so out of character with the machine, even though it's only seen when the bonnet is off.   New reservoir bolts are temporary (toilet tank bolts!) while I wait for some proper stainless ones.
Steve Late 2012 M3W
Posts: 1,338 |
Posts: 463 |
Dave 98 +8 Corsa Red 74 MGB Red
Posts: 7,068 Likes: 21
Posts: 7,068 Likes: 21 |
Very neat work. Well done
Posts: 1,673 Likes: 25
Posts: 1,673 Likes: 25 |
Andy
Posts: 1,544 |
Posts: 2,141 Likes: 43
Posts: 2,141 Likes: 43 |
That looks very neat but can I suggest you replace the crimped fuel line clips with some screw type fuel line clips, if they are the original S&S ones. The crimped ones have been known to leak and have mostly been replaced by dealers or owners. The first thing you notice is fuel on the screen and then it crazes, if you are lucky.
Posts: 1,670 |
Good advice Ian
Posts: 15,794 Likes: 14
Posts: 15,794 Likes: 14 |
Managed OCD at its best! Excellent work...
Posts: 11,610 Likes: 43
Posts: 11,610 Likes: 43 |
Super neat
Looks the tops
