2 members (Ian B, ScotiaSteve),
300
106
Topics49,860
Posts837,485
Posts: 12 |
Hi enlightened ones! Just sailed through mot again (hurrah!) but advisory that offside lower ball joint gaiter is damaged and starting to split. Car is an S3 2007. I have heard these are not easy to get or that the gaiter is not available separately, so a bit unclear what to do. Anyone have this issue and can enlighten me regarding best way forward...?
Posts: 844 |
Simon at sifab may be able to help......
Series 1 Aero 8
Posts: 5,654 Likes: 4
Posts: 5,654 Likes: 4 |
You can buy them from most major rose joint suppliers, you will have to measure the joint first to get the right size.
Martin (Deano)
Posts: 1,415 |
You can buy them from most major rose joint suppliers, you will have to measure the joint first to get the right size. You can buy the rod end ones, not the ball joint boots To the best of my knowledge the S2 thru S4 cars use different ball joints to the S1 so I don’t know where to source new boots I can make them/get them made, but I’ll need an original as a pattern Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
Have you got a picnic? I found a source for bots for the fezza and will have a look when Like get back to the UK Thursday
Posts: 318 |
I have the same problem with the lower rose joint gaiters cracked.The nut on the lower rose joint is removed,but I cannot get the rose joint stud out of the lower wishbone.I have the stud already soaked in oil for a night but that does not help.I cannot think it is a screw in fitting,or a tapered fitting.Any idea’s before using violence?The same for the upper rose joint stud,I cannot get it out of the hub housing after removal of the nut. All thoughts are welcome. Rudolf
Edit;obviously this is on Tango,an Aero8 s4
Morgan Aero8 S4 «Tango» Fisker Ocean Harley Davidson Livewire BMW R100/7 , R100R Moto Guzzi 254
I really must check before posting. Have you got a picture? I found a source of boots for rose joints for the Fezza, it was this company
Posts: 844 |
Link doesn’t seem to work...
Series 1 Aero 8
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
Try this version of the link; mcgill motorsport
Posts: 844 |
Ah yes, I’ve heard of them. Surely they’d be able to supply the correct joints/boots? Simon
Series 1 Aero 8
