5 members (Biggle, TBM, Ricosan, stumog, ScottMellor), 412 guests, and 92 robots.
Sagging Hood
Topics49,859
Posts837,474
#515298 30/05/18 12:27 PM
RobP Offline OP
https://www.gov.uk/displaying-number-plates/rules-number-plates
Seems we do not need to display front number plates in the UK
1928 Superaero Jap 3 wheeler
2013 5 speeder 3 wheeler
RobP #515333 30/05/18 02:27 PM
There has been much discussion on TM on this subject in the past and if you read the leaflet which is embedded in your link, it states that tricycles based on car bodies (sit in) require a front plate those based on motorcycles (sit on) do not. My comments in the brackets.
Many owners do not run with a front plate and get away with it, but it is a requirement for the M3W
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
That's me!
As Roy says, if you read all the details then the M3W definitely needs a front plate. Mine's on a shelf in the garage.
Mine too - although I do treat it to a run out for the MOT wink
Red Leader drive
That's me!
Very good laugh2
Reg
RobP #515355 30/05/18 04:09 PM
I fail to understand the problem really why not just screw it on guru..
As with running illegal black and silver plates, the reflective qualities of the modern plates could just save your life one day.
Each to his/her own though.
RobP #515358 30/05/18 04:37 PM
Not everybody on the road has Hawkeye vision, that's the problem..........
If it wasn't a problem there would be no such thing as Hi-Vis.
RobP #515384 30/05/18 07:18 PM
From the MOT manual ( as updated from 20th may)
Three-wheeled vehicles that don’t have a body type which is characteristic of the body of a four-wheeled vehicle don’t require a front number plate. All other vehicles, including quadricycles, must be fitted with front and rear registration plates, which must both be checked to ensure the registration number displayed is the same.
RobP #515388 30/05/18 07:55 PM
One of the previous threads is here.
My conclusion back then was that you don't require a front plate on the road but you need one to pass an M.O.T. It seems the wording has changed a bit in the last 6 years but the situation is the same.
~iw
2011 Morgan 4/4
1932 Austin 7 Chummy
That's my thinking it makes you just a bit more visible. I dont think having no front plate will let you dodge the average speed cameras.
