5 members (+8Rich, deano, JohnHarris, Robbie, gomog), 211 guests, and 79 robots.
+8Rich 66
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,877
Posts837,735
Page 4 of 5 1 2 3 4 5
Rog Offline
Originally Posted By Button
Why not cut the plywood a bit to make room for the spring.
Chances are something else would contact, maybe the dif cover
Roger
Rog Offline
My stops are set to absorb the energy rather than the bodywork.
It’s a much nicer ride woohoo
Roger
When are you going to sell me some Roger?
Nick
Originally Posted By John V6
It is a new car take it back to be fixed
I fully agree and will do so. Just wanted to know if I should take care in the meantime until taking the car back.
Originally Posted By Paul F
You may have to be quite forceful with the dealer - I learned the hard way that Morgan have quite fixed views on what constitutes a warranty issue on rear springs.
What could be the solution to ask for?
Michael
2018 Plus 4 Sport
Is this a standard damping element (I mean the rubber cone)?
Michael
2018 Plus 4 Sport
Rog Offline
Nick
Don’t hold your breath Nick. First I have to find my next car (still looking). Then I have to check my new version for fit and function on the new hoop. The old ones won’t fit as the hoop design has changed.
Yes it is but not Morgan. It’s a modified BMC Mini item.
Good luck and I hope your dealer can resolve it.
Roger
SBM Offline
[quote=Michael P
What could be the solution to ask for? [/quote]
That it stops..?
Rog, those bump stops really are great.
Just out of interest on my 2011 4/4, I used to get quite a thump when the rear suspension was shall we say exercised. The thump was much reduced when I ensured that the jack in the tool tray was secured.
The problem has now been solved:
There were two reasons:
- the propshaft touched the tunnel and
- the universal joint touched the end of a screw with which an eyelet for our dog was fastened.
The solution:
The tunnel was set approx. 1.5 cm higher and the screw was replaced by another one (instead of the hexagonal screw a door hinge screw[has a flat head] and inserted from bottom to top instead of from top to bottom as before.
Michael
2018 Plus 4 Sport
I have a question that is probably typical of newcomers (I searched the forum but found nothing - although it has certainly already been discussed):
During the first rides with our new Plus 4 I noticed a noise several times during bumps. It sounded like there wasn't enough travel. What amazes me, however, is that it wasn't a big bump. There were 2 persons in the vehicle (approx. 160 kg) without further payload.
What's beating what?
Is there anything to consider here, or are "they all doing it"?
A quick check to see the car is not sagging to one side(usually drivers) is worthwhile. There is plenty on TM on the subject.
