10 members (Grumpy2, Image, JMcL, aerotaff, John Wilcox, SteveT, DJC, petemog, Snowden, uvk33n), 128 guests, and 14 robots.
+8Rich 103
John V6 66
Old Book
Factory meet
Diss Festival of Transport
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,932
Posts838,509
AlexCreasey
Formerly known as Aldermog
Originally Posted By DaveW
Early tests were promising but I need a good run on a cold morning and its been such a wet winter!
I guess it will also help keep the water out as well!!
I get a water leak from that point, it is caused by spray from overtaking or oncoming traffic, especially HGVs on a fast A road, hitting the side of the car and getting in at the back of the door, puddling on the box section sill under the door.
DaveW Offline OP
Finally this week I made a start on the Plus 4 seals.
This time using aluminium as the base, as there is little space between the lock and the inner panel.
Starting with a paper template...............
I superglued the circular section of neoprene along the top edge of the aluminium. Fiddly and time consuming...........
Then superglued the neoprene sheet over the top. At this stage it isn't pretty.
Then add leather over the circular section from above, and another piece of leather over the flat section from below, both using aerosol adhesive, which works brilliantly.
Then cleaned up and slotted into place.........
These could be made commercially quite easily..........but not by me.......... innocent grin2
If you perfectly seal your Morgan - how do yo get the water out after a rainy day?
๐ŸŒงโ˜”๏ธ๐Ÿ˜…
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
DaveW Offline OP
There are a few holes in the floor........... grin2
SBM Offline
Oddly enough, these were a topic of conversation up in Lincs yesterday... And much awaited, I may say.
