0 members (), 192 guests, and 72 robots.
+8Rich 76
Topics49,861
Posts837,542
Page 1 of 4 1 2 3 4
I have this afternoon driven to my local sports center and driven over a high kerb in their car park .
It grounded ,and slowly i have lost all oil. The AA delivered to my garage and after inspection I can see a hairline crack in the sump.
The engine is a 3.0 litre 2967cc Ford V6 Duraratec ST220
Can anyone help me what to do next. Obviously I need a new sump .
Where is the best place to buy one ?
Any help very much appreciated .
Sorry to hear this Ray - your best bet is to PM SimonH on here he has many years professional Morgan experience and will have the answer to your question and looking forward he produces protection to avoid any similar recurrences.
No connection other than his helpful posts on here to others.
Mulfab
http://www.mulfab.co.uk/our-products/61/oil-tanks-systems/sumps/roadster-sumps-2004-2012
Offer a modified sump giving more ground clearance. Many 3.0 L Roadster owners proactively (me included) made this change.
Bert
2025 Plus Six - 1909
2009 Roadster
1983 4/4 4str
dmh Offline
We had a shallow sump fitted by Simon/Mulberry and later a sump guard from Keith at BHM.
3.0 litre Roadsters are particularly vulnerable it seems.
As you are in Brighton - I would falk to BHM first - particularly if your car has to be transported which Sarah at BHM will arrange.
Good Luck
David H
You can also gain a few mm by spacing the engine mounts.
The sump casting is very fragile, even though it looks robust.
Is it possible to fit higher profile tyres to the Roadster Dave.
Sorry to hear of the sump hit Ray
I’ve had a new sump fitted which came from SiFab. It is modified to take off about 30mm to increase ground clearance
Yes you could. Although later Roadsters are more suitable with the rear axle set slightly further back.
I have the Mulfab unit.
CBY Offline
When refurbishing the kingpins why don't install the SSL (SUPLEX) front suspension kit which allow to rise (or lower) the front clearance of roughly 20 mm depending on the spacer position.
Regards
2005 PLUS 4
Page 1 of 4 1 2 3 4
