8 members (Robbie, Mike D, verysideways, Image, DavidR, 1560, TBM, B&C Morgan), 164 guests, and 24 robots.
+8Rich 94
John V6 50
Posts837,996
rockabilly john
#522104 13/07/18 12:18 PM
Tinkering with the Roadster yesterday and a had the chance to measure the later version of the alloy tank the factory fit
I cubed it up (deducting the chamfer to the rear edge) and got 90 lts, that's over 19 gallons ! way over what I expected and what the MMC quote
Even though you'll never fill it to brim full with the airlocks, it gives a useful boost to range - although the 90 odd kg of weight is a lot to lug around
That is a big tank and to be honest, I'm somewhat surprised as that is almost double what I have on my car. I know mine is a 4/4 but I would have thought all the Trads would be similarish.
I'd double check the measurements and I'll wait now for loads of people to tell me you are correct and that I'm being presumptuous.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
Yes, I'm surprised too, I thought 45 litres was usual.
My '76 4/4 was circa 45 litres. The present '93 is around 50+ litres. But, they are both standard fit tanks from MMC.
My ‘93 4/4 was 55 litres or 12 gal. Dimensions measured and calculated volume. I was flushing the tank due to crud buggering the pump so did some extras...measured tank, new pipework/pump/extra filter. Also refilled with 1gal to check the gauge reading for reference (it was just touching the “E” with 1 gal.
19 gal seems a huge tank! TOK had a big tank for LeMans but in a production car? WOW!
As someone who makes an awful lot of Morgan fuel tanks, you can’t fit a 90 ltr tank in without modifying the wood for the spare wheel support
90 ltrs pretty much fills the volume of the body behind the rear axle
I did make a one off stainless steel tank that size for the factory for a customer who wanted to long distance tour in his new Baby Doll
Stock tank is about 55 ltrs and I don’t think the factory will have changed it
I’ve got the dimensions at the workshop
Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Yes my 2014 4/4 is 55 litre and my 2011 +4 Supersport is 55 litre
You have a one off !!!
My 2001 4/4 states 50 litres or 11imp Gallons in the instruction manual.
I believed less as when the gauge show half ful, I can fill maybe 17 or 18 litres.
But its very interestng to see the investigating other forum member ar doing.
4/4 2 seater 2001 model
About 12.5 Imp gallons who knows grin2
I just fill it at 200miles and get 23mpg if I behave.
The factory used to produce a "Sebring" tank which was reputed to hold 19 gallons or 86 litres, but I think this could have been US gallons in which case it would have been closer to 15.8 Imp Gallons or 72 litres.
I had one of these on my Plus 4 racer , and when full it transformed the car from mild understeer to dominant oversteer, when cornering at any decent pace.
It was useful for long distance touring of course as Simon points out.
My 1999 +8 has a 45 litre tank but I have never been able to get more than 41 litres in it, even after travelling for 60 to 70 miles after hitting empty on the gauge.
BTW Jon , 90 litres of petrol will not weigh 90 kilos, quite a bit less due to the specific gravity.
Andy G
1999 +8 , Indigo Blue.
