Posts837,997
Posts: 381 |
What are the sizes of your tank?
Regards 2005 PLUS 4
Posts: 8,696 Likes: 498
Posts: 8,696 Likes: 498 |
Oh no, this is where you all get to show my calcs are wrong... 750 x 390 x 320mm (minus the chamfer 100 x 40mm)
BTW Jon , 90 litres of petrol will not weigh 90 kilos, quite a bit less due to the specific gravity.
Well spotted Andy, I was just using simple terms for us northern lads
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
It's not your calcs, that does indeed add up to 90 litres.
I think it's the way you've measured it.
If you take a side view it's not a 390 x 320 rectangle because the back of the tank has a big slope on it under the spare wheel.
I don't know what the dimensions will be but you have to take a big chunk of volume off for the slope.
Bob
Posts: 1,415 |
From memory when I was making the tanks for the ARV6’s the standard tank is something like 750 x 360 x 220, less the cutout
Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 1,633 Likes: 62
Posts: 1,633 Likes: 62 |
Amazed at how small the tank is on mine, can't ever get more than 39 litres in and that very slowly the breather must be tiny
99 plus 8 indigo
Posts: 14,749 Likes: 158
Posts: 14,749 Likes: 158 |
Amazed at how small the tank is on mine, can't ever get more than 39 litres in and that very slowly the breather must be tiny Open the other fuel cap, you won't get a breather bigger than that 😁
My tank is 55 litres. I ran it as low as I dared to calibrate the fuel gauge and I managed to get 52 litres in.
Posts: 37,479 Likes: 988
Posts: 37,479 Likes: 988 |
Amazed at how small the tank is on mine, can't ever get more than 39 litres in and that very slowly the breather must be tiny Open the other fuel cap, you won't get a breather bigger than that 😁 It only has the one cap - the 2 filler models were a lot earlier Peter.
Amazed at how small the tank is on mine, can't ever get more than 39 litres in and that very slowly the breather must be tiny My handbook states 12.5 Imp Gallons but like you around 40 litres for me is the top up.
