Topics49,849
Posts837,423
Posts: 990 |
As Dave said the quality is superb. I think its essential the plate is strong enough to take the impact and i doubt thin aluminium would stand up the stress. The last thing you'd want is a broken or deformed plate flapping about underside.
Its function , in addition to a skid plate, is to protect the brake pipe thats otherwise at risk of impact.
After clouting the crossmember several times in the past i was delighted to find the skid plate solution - a brilliant piece of design and worth every penny.
2015 Morgan 4/4 (Wolf fettled) previously 2014 M3W MINI Cooper S and numerous BMC/BL relics.
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
I believe an aluminum skid plate will work for my 4/4 to help provide protection, however If your mission is hardcore rock crawling you expect to drag/slide and bounce your Morgan over rocks, then steel plates may still be your best option.
The reduced weight of aluminum, the shear strength and improved hardness and toughness over not having anything to me is far better than having no protection at all.
I’m not entirely sure its worth the extra cost vs. steel, but I will say an engineered aluminum solution does offer protection and an overall weight saving and with a lower weight, ease of install is a nice thing too.
In the end though, its a tough call and more of a personal choice.
In some respects, the steel seems to win hands down when it comes to overall engineering properties on paper, but in reality, it may be better to have a skid plate fail in some cases rather than have that potential energy transfer on to the cross member, for example it may be better to shear off a part of your skid plate at EXTREME stresses with an aluminum plate than it would be to absorb said forces on a steel plate and potentially break off bolts etc........ In other words, the failure of the skid plate may, in fact, be the skid plate doing its job...
I’m not a trained engineer, I’m a carpenter and joiner by trade.....
Craig Jezz
Posts: 486 |
I’m not a trained engineer, I’m a carpenter and joiner by trade..... Extreme Rock Crawling can be akin to the local high street pillow humps, speed humps, Steel Ferry ramps or just the plain old Stately Home entrance gates! In the development process, the Prototype was made of 5mm thick T7075 aluminium and is a clone of the 3mm Stainless steel Rub plate on sale now. The Prototype is still on the Wolf Cafe Race protecting the delicate brake pipe and curved part of the chassis that hangs low, it does show the scars of time with signs of deforming and deep scraping from all the EXTREME ROCK CRAWLING ON THE HIGH STREET AND NATIONAL TRUST STATELY HOMES! After of some 7000miles of product testing we moved to Stainless Steel, to provide a product that will have long durability for our customers and not a throw away product that needs replacing. There are a lot of damaged chassis, scraped, dented with galvanise removed at point of impact. The Rub Plate is as small as possible not to increase the possible contact area of the chassis with a folded leading edge front and rear to help stop a Mog getting hung up. Anything larger in width would increase the the forces transferred to the chassis crossmember as it would act as a leaver.
Cain
Wolf Cafe Racer 4/4 Sport
Posts: 1,245 Likes: 30
Posts: 1,245 Likes: 30 |
Wish I had one fitted a couple of years ago when the MOT tester backed the car off his ramp and caught the cross member with a loud bang & bit of buckling. He didn’t mention it either. I discovered the damage some time later. For future reference the ramp had a moveable trolly section on it that is just a bit too high. The car has been on the ramp again, you can note it clears with no one in it but with a driver seated it catches the lip of the U section. Maybe a point to note.
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
I still can’t work out why the cross member isn’t made removable. A relatively simple job as far as I can see. That would make so many jobs easier. I am surprised that the well know after market suppliers haven’t come up with one, either complete or fixings for bolting on after cutting the original? Maybe a future option? Should anyone require a car to fit one.....here I am!
Posts: 5,587 |
Wish I had one fitted a couple of years ago when the MOT tester backed the car off his ramp and caught the cross member with a loud bang & bit of buckling. He didn’t mention it either. I discovered the damage some time later. For future reference the ramp had a moveable trolly section on it that is just a bit too high. The car has been on the ramp again, you can note it clears with no one in it but with a driver seated it catches the lip of the U section. Maybe a point to note. Dreadful ! Presume you don't take it there any more ?
I’m not a trained engineer, I’m a carpenter and joiner by trade..... Extreme Rock Crawling can be akin to the local high street pillow humps, speed humps, Steel Ferry ramps or just the plain old Stately Home entrance gates! In the development process, the Prototype was made of 5mm thick T7075 aluminium and is a clone of the 3mm Stainless steel Rub plate on sale now. The Prototype is still on the Wolf Cafe Race protecting the delicate brake pipe and curved part of the chassis that hangs low, it does show the scars of time with signs of deforming and deep scraping from all the EXTREME ROCK CRAWLING ON THE HIGH STREET AND NATIONAL TRUST STATELY HOMES! After of some 7000miles of product testing we moved to Stainless Steel, to provide a product that will have long durability for our customers and not a throw away product that needs replacing. There are a lot of damaged chassis, scraped, dented with galvanise removed at point of impact. The Rub Plate is as small as possible not to increase the possible contact area of the chassis with a folded leading edge front and rear to help stop a Mog getting hung up. Anything larger in width would increase the the forces transferred to the chassis crossmember as it would act as a leaver. Hi Cain, can you please send me in the Post a Wolf skid plate for my 4/4. My Morgan is my pride and joy, therefore I wouldn't want to a risk any failures with my aluminium home made plate. Thanks for the advice on the phone today, I will send you a PM with my address.
Craig Jezz
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
It only reduces the clearance by the thickness of the plate, maybe 5 or 6mm.
The issue is that if you ground the cross-member, which is an inverted U, sometimes the Morgan will get stuck. This plate makes it far less likely to get stuck on a hump.
Thanks Dave. Does it provide any protection for the bell housing or sump?
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
No sump or bell-housing protection.
Craig Jezz
