9 members (DJC, John Winn, Bunny, +8Rich, MartO, Paulxj, James B W, Alistair, Sir Percival),
390
Topics49,842
Posts837,331
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
I had the petrol smell, the cause was a split tank on the top seam. Same with mine too.... the petrol tank had a very small split in the welded seam and needed to be replaced.
+8 4.8
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Considering the age of many Morgans it is not surprising that some systems suffer perishing and deterioration. Rubber hardens and cracks. Wiring connectors corrode etc. It is worth checking and doing replacements. The wiring under the front wheel arches is particularly heavily exposed as I have found out. Bullet connectors corroded badly so replaced and shrink wrapped to seal. Wintertime is a good time for these projects, in a decent garage!
Posts: 2,273 Likes: 38
Posts: 2,273 Likes: 38 |
Considering the age of many Morgans it is not surprising that some systems suffer perishing and deterioration. Rubber hardens and cracks. Wiring connectors corrode etc. It is worth checking and doing replacements. The wiring under the front wheel arches is particularly heavily exposed as I have found out. Bullet connectors corroded badly so replaced and shrink wrapped to seal. Wintertime is a good time for these projects, in a decent garage! and repalce the fuel tank every 18 months 😂
Craig Jezz
Yes mine is a fairly new car too.... replaced under warranty (just).
+8 4.8
Posts: 38 Likes: 1
Posts: 38 Likes: 1 |
Thanks for your thoughts folks, I'll start checking now I have an idea what to check, once the weather has cooled down a little bit!
Brendan 2018 Plus 4
