3 members (Morganmike, Luddite, Fuel.inj), 105 guests, and 48 robots.
+8Rich 89
Topics49,841
Posts837,327
Christoph
Originally Posted By Craig Jezzard69
I had the petrol smell, the cause was a split tank on the top seam.
Same with mine too.... the petrol tank had a very small split in the welded seam and needed to be replaced.
+8 4.8
BGW #524363 26/07/18 10:07 AM
Considering the age of many Morgans it is not surprising that some systems suffer perishing and deterioration. Rubber hardens and cracks. Wiring connectors corrode etc. It is worth checking and doing replacements. The wiring under the front wheel arches is particularly heavily exposed as I have found out. Bullet connectors corroded badly so replaced and shrink wrapped to seal.
Wintertime is a good time for these projects, in a decent garage!
sospan #524396 26/07/18 02:33 PM
and repalce the fuel tank every 18 months 😂
Craig Jezz
Yes mine is a fairly new car too.... replaced under warranty (just).
+8 4.8
BGW #524429 26/07/18 06:08 PM
BGW Offline OP
Thanks for your thoughts folks, I'll start checking now I have an idea what to check, once the weather has cooled down a little bit!
Brendan
2018 Plus 4
