3 members (Morganmike, Luddite, Fuel.inj), 105 guests, and 48 robots.
+8Rich 89
Topics49,841
Posts837,327
Christoph
#524214 25/07/18 03:41 PM
BGW Offline OP
We have been making the most of this amazing weather and have been out and about in our 2001, 1.8 black top zetec, 4/4 as much as possible. We have noticed of late that when we pull up at traffic lights, junctions etc there is a fairly strong smell of petrol. I have had a look under the bonnet and can't find any sign of a petrol leak. Was wondering if anyone else has had this issue or better still if anyone has sorted it! Thanks.
Brendan
2018 Plus 4
BGW #524217 25/07/18 03:54 PM
Tha first thing I would check is the rubber pipe that goes from the filler to the fuel tank.
They age harden and crack.
If it is still the original on your car it will need replacing.
On my 2003 “black top” Zetec, I changed mine 4 years ago.
Bud
4/4 "Stanley"
BGW #524218 25/07/18 03:56 PM
If it’s most noticeable when you stop, I would suggest you look behind you rather than under the bonnet as it may be that if the problem is at the rear, the smell is dissipated by the breeze as you are travelling along so you don’t smell it. Spare wheel out and have a good nose around. Flexible filler hose to tank perished or leaky tank?
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
BGW #524220 25/07/18 04:03 PM
Also check the small pipes from tank - Mark Middleton found two on my '93 that had hardened (one showed signs of exterior cracking) and when touched one virtually fell apart.
BGW #524228 25/07/18 04:38 PM
Quite often the petrol tanks leak along the top seam.
Holding a dry tissue to the edges of the tank will reveal a leak if there is one.
Another clue is if the smell is worse when the tank is full.
Nick
nick w #524245 25/07/18 05:18 PM
JCK Offline
Sounds to me like fuel vaporization in the hot environment of the engine compartment. What you smell is fuel vapor, not the fuel itself. My car does the same--and often poops out at traffic lights and other stops after running well at speed. I then have to open up the bonnet and wait 30-50 minutes for stuff to cool down.
JCK
1960 Plus 4 Roadster
BGW #524253 25/07/18 05:39 PM
Check all your rubber pipes/tubes. From filler through to engine. Rubber deteriorates and has a lifespan. Definitely a check/upgrade for a mature Morgan!
I did it on my 4/4 and it was 18yrs old at the time. Pump failed so whole system checked and bits renewed/extra filter for new pump/tank flushed.
BGW #524257 25/07/18 05:55 PM
I had the petrol smell, the cause was a split tank on the top seam.
Craig Jezz
BGW #524264 25/07/18 06:28 PM
In a modern mog there shouldn't be a small. Check the hoses as stated earlier in this thread
BGW #524281 25/07/18 08:11 PM
A friend is in the process of changing the filler hose on a 2008 car, so if yours is the original it has lasted a long time. Lift out the spare wheel and check all the hoses. If the hose is the problem, any main Morgan dealer should be able to supply replacements - my chum got his from Allon White.
Costock, UK
Disco 5
