Topics48,347
Posts813,073
Posts: 30 |
For a couple of days now I have a strange behaviour of my 4/4 Sport.
When starting the car I turn the ignition key and the lights go on as usual. So far so good.... but then there's nothing else, the car won't start when turning the key further. Zero reaction.
Turn the ignition off and on again and it starts completely normal.
This happens only when the car was left alone for a while, i.e. over night. After this 'wake-up phase' it starts always on the first attempt until you let it again sit for some time...
I am very familiar with all the 'usual suspects' like an old battery or a stuck starter. But this seems to be something electric/electronic (ignition switch, immobiliser...).
Did somebody experience similar problems?
Wolfgang
2009 4/4 Sport 1932 Three Wheeler SS other stuff.....
Posts: 1,799 Likes: 3
Posts: 1,799 Likes: 3 |
Does the engine turnover on the starter motor and then not fire or not even turning over on the starter motor at the first attempt?
Bob
Posts: 1,176 Likes: 17
Posts: 1,176 Likes: 17 |
Having the same thing on my 4/4. I swapped the keys over. Hasn’t occurred since, so possibly a key immobiliser issue.
Posts: 30 |
@ Bob, it just does nothing when turning the key further than turning on the ignition.
No klicking, no turning of starter or engine, no fireing, no dimming of the control lights.
@ Icepack: good idea to swap keys
Posts: 634 Likes: 9
Posts: 634 Likes: 9 |
It could be that the battery is too old.
Harald
Posts: 30 |
No, the battery is 2 months old and fully loaded.
With the second attempt of the ignition key the starter works with full speed.
Posts: 7,342 Likes: 91
Posts: 7,342 Likes: 91 |
Have you tried to detect error codes via OBD2? I'm not sure if the immobilizer is stored there, but it would be worth a try.
Posts: 30 |
Ah, that's a good idea with OBD2... I'll try
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
Just a thought! Does it make any difference if you allow all the check lights to go out, before starting?
Bud 4/4 "Stanley"
Posts: 9,285 Likes: 69
Posts: 9,285 Likes: 69 |
If I read it right... Key 1......Start attempt 1 no reaction. start attempt 2...starts ok. Key 2......Starts ok.
Try a new battery in Key 1.
If problem still occurs try OBD check. Try Budsters delayed start as the ecu May need a longer boot up time.
I have had a starting problem on my car (+8 Rover) when key battery was failing. New battery sorted it. We carry the spare key if away on a long trip/run just in case.
