7 members (DCH, teknome, High Hamster, Clipper, nick w, SteveT, Image),
385
113
Topics49,867
Posts837,611
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
Other Morgan models have this light on the dashboard.
My 2014 4/4 also has a light for the immobiliser, which is blinking in the way the text in your link describes. But you only see it in the very dark and only indirectly as a reflection - preferably with your head in the footwell. On our LHD cars right above the pedals.
Posts: 30 |
Ah, thanks, I'll turn off the lights in the garage, close the door and dive head first into the footwell I hope nobody shows up and asks what I am doing there
2009 4/4 Sport 1932 Three Wheeler SS other stuff.....
Posts: 37,429 Likes: 978
Posts: 37,429 Likes: 978 |
Good luck with this - my 2009 Sport immobiliser LED was just dangling at the back of the dash and I only found it when the windscreen washer pipes fell off and I removed the fibre board. The wires needed lengthening to fit the holder so I did just what MMC couldn't manage to do.
I replaced the liquorice water pipes at the same time.
Posts: 8,682 Likes: 493
Posts: 8,682 Likes: 493 |
Posts: 81 |
I had a similar problem about a year ago. When I wanted to drive home from a tourist destination, the engine did not start anymore. When I turned the key, nothing happened. Nothing! Have tried it over and over again (maybe 50 times). I tried to reset the ECU by disconnecting the battery. Nothing helped, the starter did not move. Thought on a broken battery and called the breakdown service. When I was waiting for the breakdown service, I tried again and suddenly, the engine started immediately. The breakdown service was canceled and I drove home without problems. I've never had a problem like this, since then.
4/4 sport
Posts: 1,245 Likes: 30
Posts: 1,245 Likes: 30 |
My flashing red led is visable under the LHS dash. (RHD car). When my key refered to above was playing up I often found that taking it out of the ignition & holding it a full arm reach away from the ignition, then trying again got it going. But not always. (Note my second key is still behaving)
Posts: 30 |
Ok, I found the flashing light hidden high behind the glove box.
But I also found something else: I found the problem!!!!
The fuse of the wiper was blown. I did not notice that because usually I drive the car only in the dry and everything else worked.
There must be some connection between the wiper fuse / power supply and the immobiliser resulting in the strange behaviour described earlier. I am an engineer and could not imagine such a relation, but it's a Morgan.....
Thanks again to all for your support and hints.
Wolfgang, good to hear you have solved the issue. Good luck!
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
Wolfgang, good to hear you have solved the issue. Good luck! + 1 And the wonder of Morgan wiring looms!
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Wolfgang, I don’t have a Ford engine, but have the Rover V8 with Gems system. It has a red dashboard light for the immobiliser. There is also a faint audible click when turning it off with the key fob. The EML lights up when it goes off after being non-illuminated to show the immobiliser is “on”. It goes out when the engine starts. Your car should have a similar red light...maybe UNDER the dash as some have found here.
