9 members (1854sailor, Simon, Ian Wegg, CLPlusFour, TalkMorgan, Themorganeer, MJF, Jon G4LJW, Grumpy2),
308
32
Topics48,343
Posts813,026
Posts: 534 Likes: 21
Posts: 534 Likes: 21 |
My gearbox remote is touching the propshaft. Is it caused by the black rubber bushes or just the bolts that have loosened? Can it be fixed with the gearbox in situ or do I have to take it out? Many thanks.
Dirk
1993 Morgan +4 (Connaught Green) 2009 Mini Cooper D 2008 BMW 320d 1994 Ford Motorhome
Posts: 26,748 Likes: 419
Posts: 26,748 Likes: 419 |
Posts: 3,547 Likes: 4
Posts: 3,547 Likes: 4 |
It would sound like you'd need to remove the gearbox cover at the very least to assess what the situation
Posts: 764 Likes: 8
Posts: 764 Likes: 8 |
Dirk, As John v6 says, check Gomog, no need to remove geabox, all done from the top except undoing the seat bolts. The propshaft cover overlaps the gearbox cover with a small lip so needs to be at least lifted at the front or removed. Be sure to replace bushes with Polyurethane ones which won't go squidgy.
1993 T16 +4 Lancia Blue.
Posts: 1,615 Likes: 1
Posts: 1,615 Likes: 1 |
I did this job on my '92 plus4. Not difficult but teadious and cramped. What a relief to find out that it was the rubber bushes going squidgy and not a mashed gearbox!
John 1992 plus4 connaught green
Thanks for the advice guys. I've ordered the poly bushes and solved the problem temporarily.
Dirk
The polyurethane bushes arrived in the post today. That will be the job to do the following days.
Dirk
Today was the big day. How to change the rubber bushes on the LT77 gearbox New type of door stays: Taken the seats and carpets out: The propshaft tunnel out: There are 2 screws from the gearbox cover under the propshaft tunnel: The handbrake had to be removed: The new polyurathane bushes in place (I had to ad 2 washers to increase their height: Refitting the handbrake: Job done! [img] https://farm2.staticflickr.com/1871/43653262404_852041597d_h.jpg[/img] These caused the problem: [img] https://farm2.staticflickr.com/1872/30502691458_3c90bb8cd3_c.jpg[/img] Changing gears is razor sharp again!
Dirk
Posts: 1,943 |
How about an "atta Boy" for Lorne and GOMOG. He could use some Good Cheer and a Thank You now a days.
Button
Posts: 1,745 Likes: 12
Posts: 1,745 Likes: 12 |
- nice job Dirk  I had to smile at your 'door stays' as that is the method I use when working on the Aero,albeit with the ends around a wheel spoke /door handle... James
Aero8 , Series 1 - Boston Green Mercedes EQC 400 AMG Smart Brabus Convertible Honda Monkey Z125
