3 members (High Hamster, ITP, Martin W), 239 guests, and 102 robots.
+8Rich 79
Topics49,871
Posts837,684
Rudolf
Page 3 of 7 1 2 3 4 5 6 7
I would add get one of these for your grease gun, fast easy to clip on and saves trying to wrestle the gun off the grease nipple every time. Amazing how much difference you feel with the front end freshly greased. I pump in grease until I see clean grease coming out each time. It’s messy and needs cleaning after as there is quite a lot pushed out, but I know all the grease in there is fresh. I use Lucius Oils Red and Tacky and some on here recommend it
https://www.alemlube.com.au/product/npt-quick-release-grease-gun-coupler/
Cheers from Tasmania 👍🏻😄
Cheers John
2011 4/4 - "Elrond"
2007 Elfin C3 Clubman - “Gimli”
Good advice John...
Uther now that really does look the business I shall investigate that further.
You also try unscrewing the nipple slightly. It may be so far in it effectively blocks the grease flow.
It's one of those things you buy and then wonder how you ever managed without one.
1972 4/4 2 Seater
SFG Offline
I've forgotten how you tell when there's enough grease in the top point. Anyone?
SFG
2012 4/4 Sport
SFG Offline
I have an old Tecagun (tecalemit), and the fitting on the end of the nozzle unscrews a little to make it easier to fit over the nipple. You can still get them. Works a treat. Mind you, before I fitted the remote greasing kit, I needed a full body suit. Now I put on my dinner jacket to do it.
SFG
2012 4/4 Sport
I think it was you who originally recommended it. As a result I bought one.....and it works!
I read about it on here. I would definitely have recommended it after though!
1972 4/4 2 Seater
Brilliant idea as my constantly skinned knuckles will testify. This appears on fleabay but postage is virtually as much as item itself as it has to be shipped from Oz, so looking at £50 or so! Alternatively, a “G-Coupler”, which does a similar job is available on both fleabay & Amazon for about £20 inc. delivery. I have just ordered one.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
