7 members (High Hamster, KLASG, JohnHarris, Graham, G4FUJ, John Winn, Zach, Sir Percival),
226
95
Topics49,872
Posts837,695
Posts: 625 |
I would add get one of these for your grease gun, fast easy to clip on and saves trying to wrestle the gun off the grease nipple every time. Amazing how much difference you feel with the front end freshly greased. I pump in grease until I see clean grease coming out each time. It’s messy and needs cleaning after as there is quite a lot pushed out, but I know all the grease in there is fresh. I use Lucius Oils Red and Tacky and some on here recommend it https://www.alemlube.com.au/product/npt-quick-release-grease-gun-coupler/ Cheers from Tasmania 👍🏻😄
Cheers John 2011 4/4 - "Elrond" 2007 Elfin C3 Clubman - “Gimli”
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
I would add get one of these for your grease gun, fast easy to clip on and saves trying to wrestle the gun off the grease nipple every time. Amazing how much difference you feel with the front end freshly greased. I pump in grease until I see clean grease coming out each time. It’s messy and needs cleaning after as there is quite a lot pushed out, but I know all the grease in there is fresh. I use Lucius Oils Red and Tacky and some on here recommend it https://www.alemlube.com.au/product/npt-quick-release-grease-gun-coupler/ Cheers from Tasmania 👍🏻😄 Good advice John...
Posts: 37,437 Likes: 982
Posts: 37,437 Likes: 982 |
Uther now that really does look the business I shall investigate that further.
Posts: 27,817 Likes: 749
Posts: 27,817 Likes: 749 |
You also try unscrewing the nipple slightly. It may be so far in it effectively blocks the grease flow.
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
Uther now that really does look the business I shall investigate that further. It's one of those things you buy and then wonder how you ever managed without one.
1972 4/4 2 Seater
Posts: 1,615 Likes: 1
Posts: 1,615 Likes: 1 |
I've forgotten how you tell when there's enough grease in the top point. Anyone?
SFG 2012 4/4 Sport
I have an old Tecagun (tecalemit), and the fitting on the end of the nozzle unscrews a little to make it easier to fit over the nipple. You can still get them. Works a treat. Mind you, before I fitted the remote greasing kit, I needed a full body suit. Now I put on my dinner jacket to do it.
SFG 2012 4/4 Sport
Posts: 14,009 |
Uther now that really does look the business I shall investigate that further. It's one of those things you buy and then wonder how you ever managed without one. I think it was you who originally recommended it. As a result I bought one.....and it works!
Uther now that really does look the business I shall investigate that further. It's one of those things you buy and then wonder how you ever managed without one. I think it was you who originally recommended it. As a result I bought one.....and it works! I read about it on here. I would definitely have recommended it after though!
1972 4/4 2 Seater
Posts: 2,093 Likes: 75
Posts: 2,093 Likes: 75 |
I would add get one of these for your grease gun, fast easy to clip on and saves trying to wrestle the gun off the grease nipple every time. Amazing how much difference you feel with the front end freshly greased. I pump in grease until I see clean grease coming out each time. It’s messy and needs cleaning after as there is quite a lot pushed out, but I know all the grease in there is fresh. I use Lucius Oils Red and Tacky and some on here recommend it https://www.alemlube.com.au/product/npt-quick-release-grease-gun-coupler/ Brilliant idea as my constantly skinned knuckles will testify. This appears on fleabay but postage is virtually as much as item itself as it has to be shipped from Oz, so looking at £50 or so! Alternatively, a “G-Coupler”, which does a similar job is available on both fleabay & Amazon for about £20 inc. delivery. I have just ordered one. Cheers from Tasmania 👍🏻😄
