7 members (High Hamster, KLASG, JohnHarris, Graham, G4FUJ, John Winn, Zach, Sir Percival), 226 guests, and 95 robots.
+8Rich 78
Topics49,872
Posts837,695
Rudolf
Page 5 of 7 1 2 3 4 5 6 7
Definitely a case of getting your hands dirty, weirdly satisfying, something my more modern suspended cars don't give back so much satisfaction.
Mark - No Longer driving
I was feeling fine this afternoon. Then I looked at this thread and decided it was time to do the job. Now I feel as if I have pulled every muscle in my body, including a few of which I was not previously aware. Not to mention the mucky aspect.
You’re not supposed to pump your own nipples Peter
But seriously, if you gave an engineer the task of making the task quite difficult but not impossible, you'd have to say "Well done!" In particular, I have always believed that tits should be directionally symmetrical.
laugh2
Originally Posted By Lord Unstone
Just seen this, and ordered one. Twenty quid from Amazon.
Gonna have a greasy Friday!
k
Me too
Ken A.
Plus 4 2009 Centenary Metallic Red
Plus 8 1994 Dark Green (prev)
Honda CB100 The Big One
I bought a standard grease gun and a cartridge with moly grease. I found it heavy and large, and the flexible hose made it difficult to aim for the nipple and hit it straight on. The nipples were also quite difficult to acsess, very close to the shock. So first I changed the nipples (beware of the length of the threads) to 45 degrees angled ones, that helped, but the gun itself was still to big a chunk under the Morgan. Then I got a swiss Wanner gun on ebay, NOS. Small and neat, high precicion nozzle wich goes easily (straight) on, and just as easy off (slightly levered). Rigid tube makes it easy to get to the nipple and press it on using just one hand. Injecting is no problem, and no spill. Only problem is that filling it can be messy (no cartridge), but I use my old gun to fill up the Wanner. Recommended.
Robbie the Norseman
2004 V6 Roadster
Sherwood green
Originally Posted By milligoon
I jack mine up remove the front wheels.
Clean out the old grease and grime from the nooks and crannies then fill with new grease ensuring it herniates out of the voids and clean off any excess, I then clean the discs with brake cleaner to make sure the discs aren't contaminated.
Gives me a chance to inspect the assembly for any other issues.
This is what I do; and it also gives me a chance to clean the rims properly at the same time. Usually takes 7 pumps on the grease gun. Where does it all go?
Morgan Plus 4
Royal Enfield Classic 350
Brompton M6L
Giant TCX Advanced
Absorbed by the wooden chassis?
See the London Morgan advert thread!
Originally Posted By Deejay
Originally Posted By Uther
I would add get one of these for your grease gun, fast easy to clip on and saves trying to wrestle the gun off the grease nipple every time. Amazing how much difference you feel with the front end freshly greased. I pump in grease until I see clean grease coming out each time. It’s messy and needs cleaning after as there is quite a lot pushed out, but I know all the grease in there is fresh. I use Lucius Oils Red and Tacky and some on here recommend it
https://www.alemlube.com.au/product/npt-quick-release-grease-gun-coupler/
Brilliant idea as my constantly skinned knuckles will testify. This appears on fleabay but postage is virtually as much as item itself as it has to be shipped from Oz, so looking at £50 or so! Alternatively, a “G-Coupler”, which does a similar job is available on both fleabay & Amazon for about £20 inc. delivery. I have just ordered one.
Cheers from Tasmania 👍🏻😄
Got mine. It’s a slightly larger diameter than the old nozzle but not a problem for king pin access. Works a treat and sooo easy to disconnect. Thanks to Uther for suggesting the concept.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
