3 members (JohnHarris, TalkMorgan, Graham, G4FUJ), 331 guests, and 97 robots.
Topics49,848
Posts837,406
DazMog, The Impaler, tlchzj79
#52374 04/11/10 09:43 PM
dix Offline OP
Last Monday I became the happy owner of a 1978 4/4. Beeing a happy amateur I'm quite sure that I will run into serious troubles during my restoration project and thus regret my irresponsibility several times.
However, I will rely on help from all you experts and I look forward to getting started.
Knowing almost nothing
dix #52383 05/11/10 06:31 AM
Dix, every journey begins with a start and while I'm sure you'll encounter bumps and potholes along the way, I hope the wind is always at your back and the restoration goes smoothly.
(photo updates as and when you have reason to do so please wine )
Simon #52793 15/11/10 07:56 PM
dix Offline OP
Hi Simon.
Thank you very much for your good hope. I will probably need it.
And pics will be posted along the way.
dix #52824 16/11/10 04:04 PM
Is she in immediate need of restoration? If not I would advise to drive her for a time before you start the resto. This would give you an idea of what is essential and what not.
Frank
1967 4/4 1500 Comp.
1935 Super Sports Barrelback
Bodger #52898 17/11/10 08:03 PM
dix Offline OP
Hi Frank.
Your point makes sense, but restoration is definately badly needed, and apart from that the car is taking apart in a way making it impossible to drive.
Thanks anyway
dix #52934 18/11/10 03:21 PM
Hello dix,
Will this be your first restoration of a car? If so, we could probably give you some tips about those things we learnt the hard way. I'm sure you know the basics like take a lot of pictures of absolutely everything before dismantling and of every dismantling step. And don't try to do something better than ist was original or your resto will never end.
Good luck and lots of patience
Frank
1967 4/4 1500 Comp.
Bodger #52957 18/11/10 08:53 PM
dix Offline OP
Frank,
Yes, this is my first restoration of a car. And I am a total virgin on this field. My cars has always been serviced by the local dealer, and with servicing I mean everything: Checking pressure in the tyres, water in the cooling-system, condition of brakes, changing oil a.s.o.
I am sure I will be back for advises, and as to pics I will take a lot - some will be posted when appropriate.
Thanks for the good wishes.
dix #52968 19/11/10 08:04 AM
Time Merchant
Time Merchant
Sounds like you are jumping in at the deep end Dix. I admire you for that. Good luck! I will be watching your progress with interest so keep us informed. Oh, and you could not have chosen a more worthwhile vehicle to "rescue". thumbs
2004 Plus 8
dix Offline OP
The "dream" arrived early January. And now the car is stripped down to a naked chassis.
As inspected - and expected, there is a lot of rust in the various parts, and also the chassis needs a major overhaul. Next week, I will have it sandblasted and after that I will decide, whether it is worth to spend time in replacing and welding parts of it.
dix #55131 16/01/11 08:58 PM
Chassis info & link
http://geeltd.co.uk/
