Morgan Aero 8
6 members (Franky, Jensen1960, WR142LLJPN, SteveT, RubyMog95, Vansrv6), 310 guests, and 130 robots.
+8Rich 77
Topics49,868
Posts837,639
Moggo
The Mazda MZR Super sport engine in my +4 has started making the dreaded and well documented rattle on start up. It would appear to be the well known issue in the Mazda world, failure of the what is commonly known as the VVT Solenoid Valve that controls oil to the VVT pulley on the inlet camshaft as i understand it. Failure of the Solenoid can apparently ultimately lead to timing chain failure and destructive contact between valves and pistons. A well known Mazda MX5 specialist in the North East tells me that this is possible but unlikely.
The parts to rectify include a timing chain , guides, new friction washers for the crankshaft pulley and camshaft VVT pulley and solenoid valve and come in at under £400 plus labour. Could be a cheap fix compared with a damaged engine,
There's quite a bit on the internet regarding the subject (Mazda VVT Problems) and in US Mazda has been involved in court cases due to this issue. I think i'll have it looked at in the near future. My engine has done 20k and had regular oil changes (max every 3k). Thought i had it cracked going back to a chain rather than a belt!
So i you have a timing chain like rattle on start up after being stood for a while it possibly due to loss of oil pressure in the VVT assembly.
Good luck with this - it seems a bit of a premature failure to be having at 20k.
Scary news Lowflyer..hope you get is sorted !!!
From a Supersports owner !!!
I had a 2007 Mazda CX-7 that suffered this same problem. 2.2 litre turbo. In the US it was the subject of a recall but not in Australia. It seems to be a issue with Mazda and VVT valves
Graeme: 2011 +4
The problem is to do with the pin of the VVT assembly not fully engaging and apparently is a ticking noise not a rattle - there would be no oil pressure anywhere after the car has been standing anyway. Interestingly this engine is also sold by Ford as a Duratec.
Smile, it confuses them
Lowflyer, not meant in a rude manner.
This thread is for the Aero aluminium based cars. When it talks about Supersport it means the Aero Supersport/Coupe range and not the traditional based supersport model. These are best covered in the Classic Morgan thread below it where the Trad owners will be reading and benefit from the very helpful notification.
http://www.talkmorgan.com/ubbthreads.php/forums/17/1/Classic_Morgans
