0 members (), 330 guests, and 25 robots.
+8Rich 93
Posts837,277
Page 4 of 4 1 2 3 4
meabh #457901 28/06/17 09:12 AM
meabh Offline OP
Thanks to Richard for posting the photo.
meabh #458962 03/07/17 05:29 PM
meabh Offline OP
Growl growl growl I just replaced the left bank 02 sensor and now my code reader says they are both at fault. After 8000 miles !!!!!!!!
meabh #458964 03/07/17 05:39 PM
Formerly known as Aldermog
On Tarka the sensors were identical, same length, same plugs, etc.
So that your sensors are not the same is really odd. I wonder if someone has been making changes in the past, or if the factory fitted the wrong sensor on one side of the car.
Tom at Williams said to always replace them in pairs with new as a new and old sensor will have a differing response and this can cause problems.
meabh #458982 03/07/17 07:21 PM
Sorry to hear that meabh. I am re posting the lost photo.
IMG_4304 by morgan1ste, on Flickr
meabh #459008 03/07/17 08:11 PM
meabh Offline OP
I think that I had better take advice Peter. The lengths are different for starters, as you can see from the photo and the profiles of the sensors are different too.
The left sensor has a green plug, the right, blue. In the photo the left is at the top.
meabh #532140 08/09/18 03:35 PM
Just bought this one via eBay for the pricely sum of £4.49 delivered.
Worked out of the box with my Android tablet and suitable app after selecting Ford OBD2. Guessing the sophisticated features come with the app you use not the dongle
meabh #532167 08/09/18 06:49 PM
Common thing with Fords and lambda sensors, don't use pattern parts use genuine Ford parts, (obviously if they were in first place)
Mark - No Longer driving
meabh #532459 11/09/18 02:32 PM
About the colour coding of the lamdba sensors,I think the Green is pre cat and the blue after cat .
Jimmy
2015 4/4 Sport Green
2018 VW Tiguan
1969 Morris Minor Traveller
1960 Morris Minor Saloon
meabh #532525 11/09/18 07:23 PM
It doesn't matter if it is green or blue. Both are the same. The colour is only to make the right assembly in the car.
On my 4/4 I had a pre cat sensor and a post cat sensor on the original exhaust. After change to a Librands system I only need the pre cat sensor.
It doesn't have a post cat sensor. But the problem was the cable on the pre cat sensor was too short for the new position of the cat in the exhaust,
but the not needed post cat sensor was. So I assembled them together, green mother to blue father by cut of the noses of the housing.
And everything worked as well as before. So there are now differences because of the colour. Also the sensors were exactly the same.
The colour is only to protect miss assembly with the wiring harness in the car.
Oliver
2014 sport grey 4/4
Page 4 of 4 1 2 3 4
