1 members (Marmota), 422 guests, and 44 robots.
+8Rich 93
Posts837,276
Page 34 of 40 1 2 32 33 34 35 36 39 40
Formerly known as Aldermog
My '93 has the speedo and rev counter directly in front of the driver. The important small gauges (temp, oil pressure and to a lesser extent in importance volts) can be read with the tonneau cover in place over the passenger side.
I wish Tarka did..!
The main reason I have a TomTom sat nav mounted on the screen is that it shows speed in numbers. The analogue speedometer on Tarka is impossible to read with any degree of accuracy, the markings are at 5 mph intervals and the parallax error makes things worse.
Browsing about the internet it seems that there are a lot of speedometers that use the OBDII socket to extract data, some even offer a form of "Head UP" display.
Would the OBD Data be more accurate than GPS?
It would certainly work better in a tunnel!!
Discussion of GPS Speedos and such should be moved to another thread. This thread is a sticky topic for the posting of photos of Traditional Morgan Dashboards.
Thank you all
JMC in Morgan +8 ,1998 , 4,6l
Originally Posted By MTW69
A new dashboard for the roadster, I'm happy with my work
Very envious! The standard Roadster dashboard very much suits a LHD car with the speedo on the left. I understand the leads are long enough to swap the speed / rev counter dials over. Anyone done this?
3.7 Roadster
Porsche 964 C2
JCW Mini Cooper S Cab
BMW F750GS
+4 4 1995-2002 / LM 62 +8 2002-07
Although I have a MK Dashboard, I wonder what the original dashboard of my 4/4 looked like (2005/ 2006). confused2
I dont want to change my Dashboard, ist is just a matter of interest!
My understanding is the main dials are fitted into a module which is hard wired, this is then screwed to the back of the dash in one piece and part of the harness just plugs into this
I don't know of anyone yet who was brave enough to split this moulding and see if the dials can be swopped
rid967, these are some shots of the rear of a Roadster Dash
Time Clock, fog & heated 'screen switches
Main speedo, tacho, fuel & temp all in one housing
And just a reminder of the standard front layout
This does not look very hand-made, if I may say so.
Harald
Harald
