6 members (Zach, Paul F, lez, stumog, BobtheTrain, Image), 353 guests, and 47 robots.
+8Rich 87
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,341
Christoph
#534208 24/09/18 12:21 PM
I’ve had a problem with this switch for some time now. I’ve stripped it down and cleaned the contacts but it looks an altogether substandard device. I was wondering if any forum members have had similar issues and found a more durable and better made switch.
I replaced one of mine with a refrigerator door switch as I thought that being built to handle 240v it should be ok. Bit of a faff making the brackets but it worked well.
Nick
I had the problem. It was cheap enough to order an OEM replace,ent from Morgan.
What destroyed the original was that it was wound out so far on the thread that the pressure of the pedal on it bu$&rd up the guts. Fitting the new one carefully should alleviate the issue.
Cheers John
2011 4/4 - "Elrond"
2007 Elfin C3 Clubman - “Gimli”
Cheers John
2011 4/4 - "Elrond"
