Simon, what was the grade of the oil you're using - are you getting the same problem with straight 40 oil too?
Do the oil pressure problems seem to be temperature related? My cold and warm oil pressure was fine (1938 Coventry Climax), but I was getting quite a lot of fluctuation when hot, until I realised the coolant level was slightly low so wasn't thermosyphoning correctly so was probably getting a bit too hot.
I also checked the ball valve on the side of the pump for contamination and pitting but it seemed fine; I'm going to have a look for the other one now!
I don't see any reason to bleed the gauge.
