9 members (Winigo, BigLes, JMcL, Ncik P, +8Rich, JohnHarris, Plus Four Guy, BLG83, Paul F),
273
78
Topics49,868
Posts837,634
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
All this talk of ducks.... Don’t you realise Morgan have been engineering squeaks into their cars? Why do people try to remove them when it detracts from the originality? That was fine in the past but I have it on good authority that the recent squeaks are Chinese imports. I have heard that a chinese copy is often better than the original...
Posts: 1,615 Likes: 1
Posts: 1,615 Likes: 1 |
Well I followed the above advice and squirted WD40 over my squeaky rear springs and damper bolts, followed by chain oil. The following morning, Tuesday, the squeaking was gone. Brilliant. Did 200 miles on Wednesday and Thursday and it's back worse than ever! Do they all do that?
SFG 2012 4/4 Sport
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
On an MGB you could take the springs off, separate the leaves, add lubrication and refit in a long afternoon.
Unfortunately it's a tougher job on a Morgan.........
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Stuart, have you tried the Slip and slide motion lotion, mixed with a bit of pounding fluid. That should cure it...
Craig Jezz
Unfortunately it's a tougher job on a Morgan......... Useful advice, thank you.
SFG 2012 4/4 Sport
Stuart, have you tried the Slip and slide motion lotion, mixed with a bit of pounding fluid. That should cure it... No, I haven't. Well, not for a while, anyway
SFG 2012 4/4 Sport
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
All this talk of ducks.... Don’t you realise Morgan have been engineering squeaks into their cars? Why do people try to remove them when it detracts from the originality? That was fine in the past but I have it on good authority that the recent squeaks are Chinese imports. I have heard that a chinese copy is often better than the original... . Peking duck.
Duck oil is clearly the solution.
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
As long as it isn't Peeking round the corner
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
How about soft cheese? If the mouse is eating it won’t be squeaking!
Otherwise just squirt chain lube on a few times. It will eventually help once it has penetrated between the leaves. It takes time! I don’t use WD40 just chain lube.
