6 members (Ritchie B, Bitsobrits, Tony Quinn, IcePack, Rog G, DazMog), 290 guests, and 104 robots.
+8Rich 77
Topics49,868
Posts837,642
Moggo
Page 5 of 7 1 2 3 4 5 6 7
Originally Posted By mph
Originally Posted By sospan
All this talk of ducks....
Don’t you realise Morgan have been engineering squeaks into their cars?
Why do people try to remove them when it detracts from the originality?
That was fine in the past but I have it on good authority that the recent squeaks are Chinese imports.
I have heard that a chinese copy is often better than the original... party
SFG Offline
Well I followed the above advice and squirted WD40 over my squeaky rear springs and damper bolts, followed by chain oil. The following morning, Tuesday, the squeaking was gone. Brilliant. Did 200 miles on Wednesday and Thursday and it's back worse than ever!
Do they all do that?
SFG
2012 4/4 Sport
On an MGB you could take the springs off, separate the leaves, add lubrication and refit in a long afternoon.
Unfortunately it's a tougher job on a Morgan.........
Stuart, have you tried the Slip and slide motion lotion, mixed with a bit of pounding fluid. That should cure it...
Craig Jezz
SFG Offline
Useful advice, thank you.
SFG
2012 4/4 Sport
SFG Offline
No, I haven't. Well, not for a while, anyway
SFG
2012 4/4 Sport
Ray Offline
. Peking duck.
Duck oil is clearly the solution.
As long as it isn't Peeking round the corner
How about soft cheese?
If the mouse is eating it won’t be squeaking!
Otherwise just squirt chain lube on a few times. It will eventually help once it has penetrated between the leaves. It takes time! I don’t use WD40 just chain lube.
