8 members (RichardV6, DaveW, nick w, Alan Patterson, hugo, +8Rich, ScotiaSteve, Pittsartist),
192
56
Topics49,859
Posts837,507
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Dumb question.
Why does it need greasing? If you've ever jogged in a rough tee shirt, you'll understand.
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
Dumb question.
Why does it need greasing? If you've ever jogged in a rough tee shirt, you'll understand. Rough bonnet tape rubbs the paint and the Ally...
Posts: 22,360 Likes: 353
Posts: 22,360 Likes: 353 |
Posts: 2,310 Likes: 5
Posts: 2,310 Likes: 5 |
If you can hear it creak Davie you're not driving it hard enough !!!
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
I have put some self adhesive aluminium tape on the bonnet edges with Vaseline to lubricate. The paint on the bonnet edge was rubbing off in the area of the curve down. It does protect the folded bonnet edge but so far has needed replacement . I think on my car the drivers side bonnet curve sits tight to the bulkhead tape. I have thought of rubber strips instead of the bonnet tape but will wait until the next tape replacement to try some. One thing to watch for is that the tacks used are not protruding to contact the bonnet. I punch mine down.
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
This little maintenance job has passed me by until now.
Morganatica says lube annually or every 6000 miles with oil in the periodic checks.
It never even occurred to me that there would be any major fretting but I can see where the paint is wearing thin so I will re-lube it soon, probably with Vaseline as a first trial. Or maybe linseed oil.
Bob
Posts: 27,811 Likes: 749
Posts: 27,811 Likes: 749 |
The problem with lubing them is that eventually they become very dirty & greasy.
I have just replaced mine & lined the other side with the hoop side of Velcro tape to see if that will work without grease / wax.
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
I have just replaced mine & lined the other side with the hoop side of Velcro tape to see if that will work without grease / wax. Interesting experiment - let us know how you get on. I wondered if using something smooth with silicone spray might be an alternative
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
That is why I use BeesWax John, slippy yet unlikely to ooze everywhere at temperature.
Bit like using candlewax on sash windows and drawers.
Posts: 123 Likes: 6
Posts: 123 Likes: 6 |
I use waxoil, rust proofing qualities where it touches the metal.
