7 members (CooperMan, Montegue, JohnHarris, Steve Simmonds, Mike D, yrr13, TeddyAds), 183 guests, and 23 robots.
+8Rich 91
John V6 49
Posts837,982
#537305 13/10/18 09:37 PM
I am working on a 54 Morgan. The temp gauge doesn't function. I believe the car originally may have had a capillary tube type of sending unit and gauge. This one now has an electric one. I tried testing the sending unit using hot water. Not sure where to attach the lead for the wire that goes to the gauge. Most sending units I have seen have a button that is insulated from the body of the unit. This one doesn't. When I touch the wire to the unit, it registers 'H'. Otherwise it registers "C". I have been told these sending units are no longer available.
Ideas as to a fix?
Lots about this on MOGTALK.....
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
early 1950's gauges read hot until warmed up, ie the default on the gauge is hot on the needle!
Some change the internals of the meter or buy an electronic converter gadget that converts the output from the sender to the meter if you get my drift?
Triumph Herald 1969 13/60
Morris 1970
