0 members (),
343
38
Posts837,990
Posts: 93 |
I am working on a 54 Morgan. The temp gauge doesn't function. I believe the car originally may have had a capillary tube type of sending unit and gauge. This one now has an electric one. I tried testing the sending unit using hot water. Not sure where to attach the lead for the wire that goes to the gauge. Most sending units I have seen have a button that is insulated from the body of the unit. This one doesn't. When I touch the wire to the unit, it registers 'H'. Otherwise it registers "C". I have been told these sending units are no longer available.
Ideas as to a fix?
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
Lots about this on MOGTALK.....
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 1,149 Likes: 19
Posts: 1,149 Likes: 19 |
early 1950's gauges read hot until warmed up, ie the default on the gauge is hot on the needle!
Some change the internals of the meter or buy an electronic converter gadget that converts the output from the sender to the meter if you get my drift?
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
