6 members (bmgermany, Ian Wegg, John Winn, DCH, RichardV6, Graham, G4FUJ), 321 guests, and 88 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
Draggin Offline OP
Does anyone elses oil lamp
Flicker on after a cold start?
Disconcerting to see, it does not go away by increasing revs, but does go away once the car is warmed up a little. I did check my oil tank level and it seems to be spot on.
Also only on cold start the clutch seems to have a squealing noise but if I stabbed at the clutch pedal a couple times with my toe it immediately goes away
kirkusblog.com
1952 Ford 8N
Only when it's very cold. The 20-50 I use reverts to the consistency of honey and really doesn't like to move around until warm.
The clutch sound is a new one for me.
On occasion, on either hot or cold start, I will get “no” oil light.
I sometimes got no oil light on a cold start but would work after a hot start. I checked the switch electric connection & tapped with rubber mallet & was prepared to remove it but no need its fixed.
