4 members (Bunny, Pipmac, John Winn, Alan Patterson), 245 guests, and 36 robots.
+8Rich 87
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,341
Christoph
Draggin Offline OP
Does anyone elses oil lamp
Flicker on after a cold start?
Disconcerting to see, it does not go away by increasing revs, but does go away once the car is warmed up a little. I did check my oil tank level and it seems to be spot on.
Also only on cold start the clutch seems to have a squealing noise but if I stabbed at the clutch pedal a couple times with my toe it immediately goes away
kirkusblog.com
1952 Ford 8N
Only when it's very cold. The 20-50 I use reverts to the consistency of honey and really doesn't like to move around until warm.
The clutch sound is a new one for me.
On occasion, on either hot or cold start, I will get “no” oil light.
I sometimes got no oil light on a cold start but would work after a hot start. I checked the switch electric connection & tapped with rubber mallet & was prepared to remove it but no need its fixed.
