6 members (Graham, G4FUJ, TBM, Ritchie B, PaulJ, Zach, High Hamster), 178 guests, and 104 robots.
+8Rich 78
Topics49,872
Posts837,695
Rudolf
Page 3 of 5 1 2 3 4 5
get your self fitted up with a remote greasing kit then you have easier access to the grease nipples and you don't need to remove the wheels or jack the car up. Although i jack it up when i'm greasing at home and also rotate the steering wheel a few times to maximise grease circulation, not sure if this does any good but oooo! its satisfying
Originally Posted By Deejay
31k+ on original factory pins. No gaiters. De-greased annually around rebound springs. Well greased every 500 miles top & bottom. No play detectable. Key to longevity? DIY and then you KNOW it’s done right!
Excellent advice - I am not sure remote grease points are the answer because it is still necessary to get mucky in wiping away surplus overspill to ensure none gets onto the brake discs.
I pump 20 to 25 strokes of my Wanner gun into the top nipple and 5 into the bottom nipple. Finally a second clean up of excess grease. with wheels jacked off the ground. Then push them side to side (lock to lock) without touching the steering wheel.
Graham
Octogenarian - (83)
1.8 4/4 Ivory
Toyota Yar.
VolvoV70
Andy Ed Offline OP
Deejays maintenance regime is spot on and one I will be following.
Big Thanks to all who contributed, this is a great forum.
Andy
Andy.
+1 to Dejay. I have fitted gaiters, though. Easy DIY job, and gives additional protection to the rebounds. I strongly recommend a Wanner grease gun. Small, easy to work with in a restricted space. Has a stiff nozzle, which is a great help when you press it onto the nipple, easy to do with one hand, just holding the gun. I find a flexible nozzle a disadvantage. My car originally had straight nipples, difficult to get at. Changed them to 45 degrees angled ones, greasing is now almost effortless. Not even nescessary to turn the wheels much. Plenty Wanners on Ebay. Will last a lifetime. Filling them can be messy (no cartridge!), but what I do is filling the Wanner from the big, cumbersome, cartridge-equipped, flexible nozzle gun I bought before I saw the light....
Robbie the Norseman
2004 V6 Roadster
Sherwood green
Deejay regime is a good one. I use a steam cleaner once a year to clean up excess grease from the rebound springs. Must get round to gaiters at some time.
Just got a couple of questions regarding Grease and the Wanner gun
Uh wanner wanner wanner huh!
Tell me more, tell me more
Does the nozzle go very far?
Like is it good for your car?
Uh-huh uh-huh uh-huh uh-huh
Stewart...off your meds ?!!!
hee hee
Do you have a picture of the Wanner grease gun you use, so I can have a look where I can get one.
bmgermany: sorry no picture, but just search for Wanner grease gun on ebay. They are used, of course, but as they are of superb quality, you cannot go wrong. After being discontinued for a while I think the company started making them new again, but then they are quite expensive. Ebay is the way to go. A Wanner is small and easy to operate with only one hand, including getting it onto the nipple thanks to the rigid nozzle. But you must consider angeled nipples, easy to change.
StewartS: wonderful!!
Robbie the Norseman
2004 V6 Roadster
Sherwood green
Here you have one, taken from ebay:
https://www.ebay.com/itm/Vintage-Wanner-Grease-Gun-Swiss-Made-Classic-Car-Tool-Kit-VW-Etc-Works-Fine/382597366113?hash=item5914948161:g:QYAAAOSwo0VboQtv:rk:8:pf:0
Robbie the Norseman
2004 V6 Roadster
Sherwood green
