0 members (),
255
50
Topics49,841
Posts837,324
Posts: 265 |
Just received a price of essentially $2k for the MMC Stage 1 kit (parts only), including intake, pipes...and an ECU flash that can only be performed by the factory.
Is this normal?
Firstly, I was under the impression that a Stage 1 does not require an ECU flash and secondly that the cost was more reasonable. Thoughts?
'17 M3W: '08 Ural Gear-Up
Posts: 367 Likes: 12
Posts: 367 Likes: 12 |
I'll recommend Garage 56 Stage 1... https://www.garage56.co.uk/product/stage-1-kit/Don't know what it does to warranty but it does sound sweet!
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
The Could the differences in price and specification be anything to do with quoting for a Euro 4 M3W maybe? Stage 1 kit didn't require an ECU flash as the adaptive maps can cope with it. The same applies for the G56 kit. Both benefit from an unlocked ECU and a rolling road set up though. I would vote for the G56 kit as well because I am a satisfied customer. Performance and running are greatly improved and it's got a deep rumble but is not too loud. If you plan any long journeys you will appreciate that after a few hundred miles.
Posts: 265 |
I doubt the US dealer made a mistake by ordering for the wrong vehicle. I too thought the stock mapping could handle the increased air flow and didn't need a flash until Stage 2. I'm told the vehicles are tuned a bit lean for US DOT emissions standards....is it possible a remap is needed for US vehicles and not others?
I do plan to enjoy longer journeys. And because payload weight/distribution will vary quite a bit, I'm also looking at the Supplex shocks.
Posts: 265 |
I've heard great things about this option. The Stage 2 looks like fun too! I'm curious if the calibration they refer to is DIY or requires a professional?
Posts: 637 |
The factory takes the view that it will invalidate the warranty. Whether they’re legally entitled to take that approach is a different matter but, to avoid any aruments, I went with the factory Stage 1 kit. I have to say I love them. The noise is very loud but, after my first set of Stage 1 pipes failed within a couple of weeks of them being fitted as the weld went on one of them, I really missed the noise when I had the original pipes back put on until a repalcement set of Stage 1 pipes was fitted recently (under warranty). It was so good to get them back. The engine does run quite a bit more freely and, to my (slighly ringing) ears, the sound is great. Don’t underestimate the volume though. The G56 ones are definitely quite a bit quieter (with a more bassy sound).
Posts: 637 |
I was a liitle (actually, very!) dubious about the volume of the factory Stage 1 pipes when I first had them fitted but, after doing 2,000+ miles with them on this year’s Gridelwald trip, I am sold on them. I have the Spax adjustable shocks on my car and I can’t say how they compare with the standard ones as mine were specced from new and already fitted when I took delivery of the car from the factory but what I can say is that the suspension set-up of my 2017 car is just so much better than the 2013 car I originally had. Red Leader has just recently had the same shocks fitted and I’m sure he would be happy to give his views on how he has found them.
Posts: 439 Likes: 3
Posts: 439 Likes: 3 |
+1 for the factory Stage 1 pipes. They are certainly loud when you're "getting on it" a bit, but I don't find them objectionable during part throttle cruise. And a helmet or at least ear plugs are recommended for long distance high-speed cruising anyway.
Additionally, they partially mask the noise of the bevel box and various rattles, so a double benefit :-)
Posts: 12,256 Likes: 317
Posts: 12,256 Likes: 317 |
+1 for the factory Stage 1 pipes. They are certainly loud when you're "getting on it" a bit, but I don't find them objectionable during part throttle cruise. I'm sure the factory pipes are fine, but some of the setups I've heard on M3Ws are frankly ludicrous. One came through Stroud last year, I have no idea who it was, but is was ear-splittingly loud, I'm surprised it didn't break any shop windows. From the comments people were making I don't think the locals were impressed.
Posts: 8,659 Likes: 407
Posts: 8,659 Likes: 407 |
Is this normal?
Firstly, I was under the impression that a Stage 1 does not require an ECU flash and secondly that the cost was more reasonable. Thoughts? You are/were correct on both counts. The MMC stage 1 kit when it was available came out at a little under £1000. You got the silencer pipes and a complete S & S filter kit, both of which when fitted did not require an ECU upgrade. Suggest you speak to the parts department for an explanation, although it could be related to Euro 4 spec engines.
