Topics49,869
Posts837,654
Posts: 28,904 Likes: 352
Posts: 28,904 Likes: 352 |
I gave up years ago.
Posts: 37,433 Likes: 978
Posts: 37,433 Likes: 978 |
20 years ago for me
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
I've just had three days in the Garage fitting Mulfab bearings to my Plus 4, along with Cain's lower bearings, and some additional splash guards under the front wings, and an exhaust manifold heat shield........ Oh and some cleaning up, obviously. I'll get it all posted over the weekend. I'm aching a bit tonight, as it's quite hard work!!!
Posts: 327 Likes: 3
Posts: 327 Likes: 3 |
Thanks Dave. I now feel inadequate!
Tom 2018 Plus 4
Posts: 8,683 Likes: 413
Posts: 8,683 Likes: 413 |
I've just had three days in the Garage fitting Mulfab bearings to my Plus 4, along with Cain's lower bearings, and some additional splash guards under the front wings, and an exhaust manifold heat shield........ Oh and some cleaning up, obviously. I'll get it all posted over the weekend. I'm aching a bit tonight, as it's quite hard work!!! Just be careful you don't turn the car into a hedge when you leave your drive as the ultra light steering catches you out
Thanks Dave. I now feel inadequate! Give it time and you'll feel less inadequate!!! It's how I relax!!
I've just had three days in the Garage fitting Mulfab bearings to my Plus 4, along with Cain's lower bearings, and some additional splash guards under the front wings, and an exhaust manifold heat shield........ Oh and some cleaning up, obviously. I'll get it all posted over the weekend. I'm aching a bit tonight, as it's quite hard work!!! Just be careful you don't turn the car into a hedge when you leave your drive as the ultra light steering catches you out Haha! yes I'm looking forward to the improvement!
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
I've just had three days in the Garage fitting Mulfab bearings to my Plus 4, along with Cain's lower bearings, and some additional splash guards under the front wings, and an exhaust manifold heat shield........ Oh and some cleaning up, obviously. I'll get it all posted over the weekend. I'm aching a bit tonight, as it's quite hard work!!! With the front end all freed up, it will be interesting to see if you get any more Morgan Dance movement. I've always thought that having a bit of tightness helps to damp out the movement so yours will be an interesting comparison before and after. Let us know when you test it.
Bob
My Roadster originally had damper blades Bob.
I fitted Mulfab bearings when I did the kingpins and dumped the damper blades.
The steering was transformed. Much lighter (too light really) and no wobble. So to give it better feel I'm fitting a steering damper over winter. This was recommended by my Guru.
Posts: 3,825 Likes: 69
Posts: 3,825 Likes: 69 |
I'd like some form of damping....what sort of damper are you fitting Dave? Nick
