Topics49,841
Posts837,312
Posts: 68 |
My car is approaching 2 years old with just over 9k of dry (non--winter) use and now it's having to go back to the factory in the New Year for a re-spray of all four wings (at least). Micro-blistering of the paint is occurring... I'm told, "..this happens sometimes..."... Anybody else had this problem and know what the actual cause is?
LWH
LuckywhiteheatheR
2016 Aero 8 1960 MGA Roadster 2003 Ducati MS 1000
Posts: 2,432 Likes: 66
Posts: 2,432 Likes: 66 |
On the posetive side you will get all your little stone chips done.
Em
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
Type in Paint Man and search into it and it should help you have a rough idea of the whats and whys of paint .
Posts: 14,009 |
“ Micro-blistering of the paint is occurring... I'm told, "..this happens sometimes..."..“
On a two year old car? No way should it happen sometime! Bearing in mind that the wings and body are sprayed at the same time, there’s always a chance that the rest might suffer at some stage from the problem. I’d insist that they respray the complete car.
Posts: 5,654 Likes: 4
Posts: 5,654 Likes: 4 |
Most likely cause is moisture in the air or on the cars surface at the time of spraying.
Martin (Deano)
Posts: 68 |
[quote=aerotaff]On the posetive side you will get all your little stone chips done.
The paint protection film seems to have been doing its stuff in that regard... no stone chips to speak of so far...
LuckywhiteheatheR
Posts: 20 |
+1 deano, Had it occur on a narrowboat I painted a couple of years back, but, could also be evaporation of solvent as previous coat not dried sufficiently. I would inspect areas that still look ok with a magnifying glass just to be sure.
Andy.
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
We had this on Caroline's Mercedes E350 Coupe when it was 5-6 years old. Mercedes re-sprayed the car under warranty.
I was told that all Mercedes cars painted a particular red and between specific dates had the problem.
The cause was an unexpected reaction between the primer and the first colour coat, due to a formulation change in the primer. The paint maker didn't think the change was sufficient to need to be declared. The bubbles lifted the clear coat slightly.
You don't say what the colour was, but it does seem to have a greater frequency with red pigments. Very strange.
Posts: 11,524 Likes: 312
Posts: 11,524 Likes: 312 |
The coupe required a few attempts unfortunately.
Posts: 68 |
............ You don't say what the colour was, but it does seem to have a greater frequency with red pigments. Very strange. The paint colour is Kilimanjaro Sand Peter, so not quite in the 'red' spectrum...
LuckywhiteheatheR
