1 members (Ian B), 281 guests, and 97 robots.
Topics49,847
Posts837,389
Page 3 of 3 1 2 3
Originally Posted By Paul F
Use a Stanley craft knife to slit the belt along its axis. Fit the new belt beside the remains of the old one. Then remove the old belt completely and slide the new belt into position. This is not a recommendation on my part - just something I heard about - possibly on TM!
Edd China.
Best Regards
Lang may yer lum reek
Heinz #546681 06/12/18 10:25 AM
Originally Posted By Heinz
Thank you!
Literally meaning ‘long may your chimney smoke’, this is the best way to wish someone a long and healthy life.
You know a bit of Jockinese, Heinz.
Best Regards
Edd China.
So did Fuzz Townshend (car SOS)
I would recommend a cambelt change every 5 years, regardless the milage.
The cambelt on our Ford motorhome was 6 years old and had done only about 15k km and all the teeth came off. Result a few bent push rods. But no damage to the valves.
Dirk
1993 Morgan +4 (Connaught Green)
2009 Mini Cooper D
2024 Mercedes GLC
1994 Ford Motorhome
The S & S V twin in the M3W engine is zero interference even with optional higher lift cams. Probably just as well given the spate of crank timing pinion bolts unscrewing with early batch.
I wonder how many modern car engines are though?
Spoke with Phil at Ledgerwood Morgan for a definitive view - it’s 5 years or 60k miles. Will book it in when the better weather comes (I know!!!)
Tony
1994 Connaught Green Plus 4
a quote from the fordownersclub forum by a mechanic:
On the 1.4/1.6 Duratec (including the TI-VCT) Petrol engine the timing belt interval was changed by Ford from 100.000 Miles/10 Years to 100.000 Miles/8 Years.
The reason for this is that between 8 and 10 years many timing belts failed which resulted in major engine damage.
Hi guys, I need some help with the crankshaft torque setting after changing the timing belt.
All the video's I've looked at on YouTube and also the Ford manual clip posted earlier in this thread (for the 2011 engine) state the torque should be 100Nm plus 90 a further deg's, BUT the Gates timing kit which i have used states 2 differnt torques depending on the bolt size?, For the 14mm bolt they suggest 40Nm plus 90 deg's where as the larger bolt (18mm I think) they say 100Nm plus 90 deg's.
As Gates are good make, is it safe to assume they know what they are saying? If the bolt isn't tight enough the crank pulley could slip and the valves could hit te pistons....where as over tightening the bolt could snap and get stuck in my crankshaft. Does anyone know for sure which torgue to use on the 14mm bolt please? I'm hoping to get the job finished tomorrow. Thanks ps mine is a 2009 1.6 Sigma engine.
2009 4/4 Sport in Red
2022 Harley Davidson FXLRS Low Rider S
1977 Triumph Stag
Hi all, it's ok, I've found the info i need :-)
http://replace-timing-belt.com/how-to-replace-timing-belt-on-ford-focus-1-6i-2007-2011_/
It's 40Nm plus 90 deg's for mine :-
1977 Triumph Stag
Page 3 of 3 1 2 3
