4 members (Massi_torino, MJF, Simon, TalkMorgan), 222 guests, and 96 robots.
+8Rich 74
DaveW 52
Topics49,867
Posts837,628
Moggo
#546766 06/12/18 07:09 PM
I don't know if this is a "It's a Morgan they all do that" but my wipers refuse to work unless the battery is fully charged?
If I don't use the car for a week the wipers only work after driving a few miles even if it is left on a trickle charger.
The only thing I can think is there is not enough current to move the motor?
Probably a high resistance somewhere in the circuit. Check connections especially earth and any fuse that might be in the circuit.
It shouldn't be like that. It sounds like a reluctant motor. So either do a clean/service or replace it.
It could also be stiff spindles or rack but you can test that by hand with the motor disconnected.
And also test the motor with the rack disconnected.
Thanks for your thoughts, I'll check connections and fuse first then look at spindle and motor next and let you know how I get on.
My wipers were reluctant to start and so I took the cover off the worm and nut drive to find that the nylon gears were running dry, just redistributed the grease into the meshing surfaces and it's been fine ever since.
It could well be the extra volts are helping yours overcome the inertial drag somewhere in the drive train.
They are now working as they should. Cleaned up the terminals and everything looks ok. If I get any more problems Thanks to you guys I know what to look at. drive
thumbs
Remember the age of your Morgan !
With advancing years the “hidden” areas decline.
There is a good case for checking and overhauling systems after a few years.
I have done it on a 1993 car fuel train after a pump failure. Draining, flushing, new flexible hoses, extra filter etc.
Same for the wiring under the front wings on the current 2002 car.
Very exposed and bullet connectors.......on finding a bad connection due to corrosion it was overhauled. Did the both sides while at it. New connectors and shrink wrap should see me good for a good while.
Gave the brake system a once over before last MOT....all good. New fluid due next year though.Starting to think about future options - Flexible pipes are good but will upgrade to braided. Will I/ won’t I calliper upgrade? New discs at same time?
Alloy wheels are due a refurb early next year when new tyres put on.
I enjoy working on the Mog so it is not a chore.
