1 members (Saxonian),
161
88
Topics49,847
Posts837,389
Posts: 671 |
Remote kit for me. I can still slide underneath for some tinkering but the remote kit makes life easy and I’m all for that.
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
Whatever system you use, it's important to regularly inspect underneath for the reasons listed above.
Posts: 37,407 Likes: 977
Posts: 37,407 Likes: 977 |
I wouldn't entertain a remote kit get under there and check it all over and tighten up as necessary, greasing the damper blades as well it's all part of the getting involved ownership. As Graham says it does take a little longer these days to get up after though
Posts: 990 |
https://www.wolfperformance.co.uk/remote-greasing.htmlDon't have it myself but I see the kit isn't very expensive so why not? Just a thought - if its a new car it won't have damper-blades to worry about either
2015 Morgan 4/4 (Wolf fettled) previously 2014 M3W MINI Cooper S and numerous BMC/BL relics.
Posts: 33 |
The remote kit makes it so easy, especially when touring. Not many people will lay on their backs in a dusty car-park away from home to grease the front suspension, but with remote greasing it's a simple, clean 5 minute job - and it must be better for both the longevity of the suspension and effort required to drive.
Posts: 1,245 Likes: 2
Posts: 1,245 Likes: 2 |
I'm with you on that Graham! Don.
Posts: 5,464 Likes: 171
Posts: 5,464 Likes: 171 |
Managed without remote greasing since 2003. Fitted a kit this year after a frustrating 1/2 hour in an underground car park in Austria. It doesn’t eliminate the need to get underneath when at home. It just makes keeping on top of things when touring a whole load easier.
Posts: 45 |
...is it not also desirable to wipe off the old grease that gets pushed out?...so you need to get under the car to do that either way.
Andrew Rosie the Claret red Plus 4 (manually greased)
Posts: 1,615 Likes: 1
Posts: 1,615 Likes: 1 |
Wiping above your head is easier than manipulating a grease gun above your head, into a dark inaccessible place, especially if you are touring abroad as Paul says
SFG 2012 4/4 Sport
Posts: 407 |
Oakmere fitted mine at new and they work a treat.
Yes, you still need to get under to wipe off the excess but as SFG says this is an easy and quick enough task.
Stuart
Rich Maroon and Royal Ivory (ish) +4
