7 members (Hamwich, TBM, Montegue, SteveD, Eastertown, Barkingdog, Alan Patterson),
341
35
Topics49,845
Posts837,374
Posts: 31 |
Break warning light on all the time I have checked levels can't find the reason why and it's driving me nuts next step is a bit of black tape over it
Posts: 2,190 |
Break warning light on all the time I have checked levels can't find the reason why and it's driving me nuts next step is a bit of black tape over it Is the sender sticking? G
GLLHG
Posts: 37,407 Likes: 977
Posts: 37,407 Likes: 977 |
Break warning light on all the time I have checked levels can't find the reason why and it's driving me nuts next step is a bit of black tape over it Holed (sunken float) or picking up a stray earth along the path somewhere is as good a starting point as any. Or maybe just a little "break dancing" see your original post !
Posts: 28,894 Likes: 350
Posts: 28,894 Likes: 350 |
I know you've put the info up before, but which model and age of car?
Cheers,
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
Some dual circuit master cylinders have a shuttle between the circuits which moves when one circuit loses pressure, or is bled.The later MGB was like this and if the shuttle isn't centred, the warning light stays on. I assume there's some sort of similar system on Morgans. It can be centred by bleeding but it's trial & error. Maybe that's the problem.
Posts: 27,807 Likes: 749
Posts: 27,807 Likes: 749 |
Could it be the switch on the handbrake?
Posts: 462 |
If my memory serves me the trick for centering the shuttle is to hit the brake pedal hard while the bleeding valve isn't fully closed. I have done it last time 25 years ago.
Frank
1967 4/4 1500 Comp. 1935 Super Sports Barrelback
I might be the handbrake switch John, the bracket can bend.
