10 members (Robbie, Tweed19er, Morganmike, Themorganeer, tommog, Alistair, JohnHarris, Graham, G4FUJ, SteveT, rossocorsa), 183 guests, and 59 robots.
Topics49,846
Posts837,383
#54712 02/01/11 04:31 PM
booty Offline OP
Break warning light on all the time I have checked levels can't find the reason why and it's driving me nuts next step is a bit of black tape over it
booty #54713 02/01/11 04:50 PM
South Wales Correspondent
Is the sender sticking?
GLLHG
booty #54714 02/01/11 06:22 PM
Holed (sunken float) or picking up a stray earth along the path somewhere is as good a starting point as any.
Or maybe just a little "break dancing" see your original post ! joy somestick
+8Rich #54720 03/01/11 09:20 AM
I know you've put the info up before, but which model and age of car?
Cheers,
Some dual circuit master cylinders have a shuttle between the circuits which moves when one circuit loses pressure, or is bled.The later MGB was like this and if the shuttle isn't centred, the warning light stays on. I assume there's some sort of similar system on Morgans. It can be centred by bleeding but it's trial & error. Maybe that's the problem.
DaveW #54729 03/01/11 11:42 AM
Could it be the switch on the handbrake?
John V6 #54775 04/01/11 02:34 PM
If my memory serves me the trick for centering the shuttle is to hit the brake pedal hard while the bleeding valve isn't fully closed. I have done it last time 25 years ago.
Frank
1967 4/4 1500 Comp.
1935 Super Sports Barrelback
Bodger #54786 04/01/11 05:36 PM
I might be the handbrake switch John, the bracket can bend.
