Morgan Aero 8
10 members (JohnHarris, AlyMatt, Image, 2949olivier, Hamwich, Cerberas, James B W, Sir Percival, Ricosan, Bunny), 249 guests, and 77 robots.
+8Rich 79
Topics49,871
Posts837,682
Rudolf
#548384 16/12/18 05:25 PM
Hi all just been browsing Pistonheads (well it is horrible outside) and saw this late S1, but it has an access panel (I'm assuming) on the front wing do any of you guys have the same thing I didn't on mine confused2 https://www.autotrader.co.uk/dealers/ess...garage-10008229
2017 Metallic Black +4 GDI
Functional but not very pretty on a car of this class.
never seen this before Malcolm ;it's not too well done either scared
I'm guessing this is to allow access to the power steering pump - but not sure why you would need this on a regular basis?
I could (almost) understand if it were on the other side to allow you change the air filter without removing the wing.......
James
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
This is the 60,000 mile car. Maybe it’s needed the pump changed several times......
Simon
Series 1 Aero 8
It’s not a series 1 either...
Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Online Happy
What a horrible and unnecessary modification.
It also has other non S1 modifications.
Martin (Deano)
miles of smiles
miles of smiles
Quite like the car, not a bad price but that panel is a mess, wouldn’t be so bad if the bodge was painted to match.
SimonH #548429 16/12/18 11:08 PM
Simon @ SiFab.co.uk
Really I thought it was a late S1 or S1.5 as they say going by the half dash and bootlid.
Smile, it confuses them
Having a look at the photos this has some odd parts about it.
2004/5 plate is at the end of S1 or near start of S2 phase ?
It has the small plastic covers around the front indicators of later S2.
It has two windscreen wipers which are normally early S1 (2000)
It has bolted alloys not centrelocks which were on a few late S1 and after market alloys which don't look too bad.
It appears to have the earlier S1 sized brakes.
S1 door handles
S1 boot lid
The panel is a total fail.
It appears to be an early car registered late?
The MOT history is a little interesting - steady use, lots of passes, and then in the last 3 years the recorded mileage was 50,632 in 2016, 11,193 in '17 and 3,543 in '18.
It's a time warp!
Will
Formerly Aero S5 #80
