7 members (TeddyAds, nick w, RobC, JMcL, TalkMorgan, RedThree, Liam1961),
296
92
Topics49,859
Posts837,469
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
There's probably some legal infringement going on there. Lets hope "The Council" don't get onto it.
I would mount a square number plate on the raised section.
Posts: 37,416 Likes: 977
Posts: 37,416 Likes: 977 |
The bins are the local authorities property hence the earlier jobsworth comment. We had a similar "issue" down here with a friend of mine testing his outboard in one  when said jobsworth turned up - he just cracked the throttle open and it got a bit wet and noisy and it crept back in it's hole. Unlike in Germany you had to buy your own galvanised bin for DM50 back in 1976.
Posts: 11,527 Likes: 312
Posts: 11,527 Likes: 312 |
Well I do seem to remember a thread on here not so long ago about fitting a fibreglass wing on a trad ?
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Which came first, the Land Rover Wing or the Wheelie Bin?
It was a covalent bonding process  Oh alright he crashed into it and
Posts: 1,947 |
Has it been converted to electric as all cooling is blanked off?
Posts: 3,824 Likes: 69
Posts: 3,824 Likes: 69 |
Which came first, the Land Rover Wing or the Wheelie Bin? Very good! Nick
Posts: 2,433 Likes: 66
Posts: 2,433 Likes: 66 |
If you throw a few bags of cement in the back of that Landie it would become a Bin Laden.......ouch.
Em
Our bins are branded MGB. It was said that the designer hated MGB's so much that he deliberately named his bin design....MGB.
He must have had a bad one...........OK most of them are quite um, bad........
But good ones are very good.
Posts: 6,668 Likes: 433
Posts: 6,668 Likes: 433 |
Has it been converted to electric as all cooling is blanked off? That'll be the special 'winter' running mode. A desperate attempt to get a tiny bit of heat in the cab....
