1 members (Ian B), 335 guests, and 111 robots.
+8Rich 76
DaveW 52
Topics49,867
Posts837,614
Page 2 of 5 1 2 3 4 5
DaveW Offline OP
Originally Posted By KEVFITZ
You can't even give a complement these days without somebody having a go at you !!!!
Maybe time to move to a proper car forum like Ferrari and discuss the merits of owning a Morgan !!!
xx
Just go and stand in the corner over there........
DaveW Offline OP
Originally Posted By Rob Thornton
Great explanation of the process Dave. Love the wheel supports too. Presumably you always use four of these together?
Thanks Rob.
Those wheel supports came from some spare timber I had laying around. I made four and they can be used like that for maximum lift or on their sides for a bit lower.
I use either a pair (front or rear) or all four........
They are invaluable!
You do know that if you bought a +4 Supersports all your wished for modifications and performance updates would have been fitted at the factory !!!
Just saying !!!
Dave ..when can I come out of the corner..I think I need the toilet !!
DaveW Offline OP
When you stop talking.
Silence
DaveW Offline OP
The toilet is outside....
SBM Offline
Ah, yes..
Yorkshire..
http://www.suspensionsupplies.co.uk/products/4593177137
Google is your friend.
I guess battery gets in the way ?
DaveW Offline OP
Yes it does.....
Depending on model and year of Morgan the Panhard rod may need to be designed so as to avoid the fuel outlet pipe from the fuel tank. Typically changes whether it is designed to be mounted to the left side, or right side, of the chassis.
Mike Smith
2007 +4
