Topics49,866
Posts837,595
Posts: 22,365 Likes: 354
Posts: 22,365 Likes: 354 |
You can't even give a complement these days without somebody having a go at you !!!!
Maybe time to move to a proper car forum like Ferrari and discuss the merits of owning a Morgan !!!
xx Just go and stand in the corner over there........
Great explanation of the process Dave. Love the wheel supports too. Presumably you always use four of these together? Thanks Rob. Those wheel supports came from some spare timber I had laying around. I made four and they can be used like that for maximum lift or on their sides for a bit lower. I use either a pair (front or rear) or all four........ They are invaluable!
Posts: 2,310 Likes: 5
Posts: 2,310 Likes: 5 |
You do know that if you bought a +4 Supersports all your wished for modifications and performance updates would have been fitted at the factory !!!
Just saying !!!
Dave ..when can I come out of the corner..I think I need the toilet !!
The toilet is outside....
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
The toilet is outside.... Ah, yes.. Yorkshire..
Posts: 321 Likes: 3
Posts: 321 Likes: 3 |
Depending on model and year of Morgan the Panhard rod may need to be designed so as to avoid the fuel outlet pipe from the fuel tank. Typically changes whether it is designed to be mounted to the left side, or right side, of the chassis.
--------------------------- Mike Smith
2007 +4
